861 ford dies when governor kicks in u
   / 861 ford dies when governor kicks in u #1
dselsor
VANDALIA MO
861 FORD
My 861 ford dies when I give it gas to fast and when the governor kicks in. It idles fine
   / 861 ford dies when governor kicks in u #2
Would you like to reveal which type fuel it use's? How does it act if hooked to a load such as 2 bottom plow and throttle slowly increased? Sitting still,in neautral at fast idle then suddenly given 3/4tr throttle?
How long have you owned it? Did it run well then one day start this? Did you change anything/work on it just before this begain (especially anything with throttle linkage)?
   / 861 ford dies when governor kicks in u #3
If it is a gas job and stumbles when you give it throttle, see if a little choke helps.. If yes, open the main needle a half a turn and re-check. Too lean on the main and they will stumble on acceleration.
If a diesel, your Roosa master pump may have a broken plastic governor ring..
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
