8N Carb Settings
/ 8N Carb Settings #1
8N_John
Kearney, Missouri
1952 Ford 8N
What is the correct setting for each of the 3 valves on an 8N (1952 model). A couple weeks ago, I took the carb apart to put in a new float and messed around with the valve settings. Just got it running again today...it ran pretty good for the first 15 minutes. Then, it kept acting like it wanted to die and was jerking on me. I tried it for another 10 minutes or so and it kept doing the same thing. It did seemed to run a little better when I pulled the choke out slightly...but it still jerked a little.
I will get new spark plugs and see if that helps, but in any case I'd like to make sure the valves/screws on the carb are set correctly. I understand the setting may vary a little for each tractor, but is there a general rule of thumb to the settings?
/ 8N Carb Settings #2
If you are talking about mixture adjusting screws, there is no "correct" setting; however, 1 1/2-2 turns out is generally a good starting point for all mixture screws. Running better with choke on is a sign of a lean mixture, (not enough gas). Carb probably needs cleaning.
/ 8N Carb Settings #3
Could be a restriction in the fuel lines up to the carb. Pull the fuel line off to the carb and see how the flow volume looks. If it's just a trickle may be clogged lines or tank outlet. Could also be fuel cap venting problem. When you pop the cap does it hiss/pulling in air? Did you get the float level set properly? Horizontal to a little angled up from horizontal to the base.
Ditto on the settings, usually a good starting point....
/ 8N Carb Settings #4
I have a '51 8N and have had it for 30+ years. I have had every bolt out of it at least once, over the years. Take your sediment bowl off, and if there is still a screen at the top of the bowl, make sure it's clean. And if it is and the tank is low on fuel, blow 20-30 lbs of air pressure back through the fuel bowl to the tank. The bad thing is people don't use the first half turn to three quarters turn for the reserve part of the tank, and it will plug up. Highly recommend using the reserve tank on the valve most of the time, to let any dirt/moisture go through the system. Like the other gentleman said - 1 1/2 to 2 turns on the main jet, 1 turn on the idle jet . With the fuel valve shut off (necessary on these old tractors, when not in use) you can take the low air pressure and remove both jet needles, and blow air back through the carb to remove any junk, but the problem is probably in the fuel tank reserve valve portion. Good luck - Yugo
/ 8N Carb Settings
The attached drawing refers to the:
-Main adjustment needle
-Idle speed adjustment screw
-Idle fuel adjustment needle
Assume the 1.5 to 2 turns out refers to the main adjustment needle? Does 1 turn out apply to both the idle speed and idle fuel adjustments??
/ 8N Carb Settings
Forgot the link...here it is. Ignore the colored arrows.
/ 8N Carb Settings #7
Remember.. the main needle is out to enrich.. while the idle needle is backwards. I'd start 1 to 1.5 turns on each.
Use the idle speed set screw to set your max idle rpms.
I also agree.. if it needs some choke.. or stumbles on a quick acceleration.. may be a lean mix. ( or vacume leak.. )
Soundguy
/ 8N Carb Settings
Checked the float setting today. It was set more like .35 inches rather than .25 inches. I adjusted to 0.25. Will see if it runs better tomorrow. I will try to get the screw/needle settings figured out as well. Thanks for the info.
Kubota L3130 (A53317)
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2015 John Deere Z950M 72in Zero Turn Mower (A59228)
2015 John Deere...
2013 Ford F-150 Pickup Truck (A59230)
2013 Ford F-150...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
