8N Pto Leak
   / 8N Pto Leak #1
8n4jr
Mattawan,MI
FORD 8N ,JD 110 &210
Hey all,
I have a 51 8N that the seal on the rear pto leaks bad, it very low on fluid so I'm gonna drain whats left and replace, my question is-
When I try to remove the bolts that have never been apart, should I try a breaker bar, 6 or 12 point socket or should I use air impact, seems everything I touch on this old tractor fights me, I am trying not to break the bolts in the casting, started spraying last night with 2 different types of penetration oil.
Any advice to help me not break off the bolts much appreciated!
   / 8N Pto Leak #2
air impact, with impact sockets (generally colored black) and normally 6 point.
12 point, breaker bar and more likely to strip the heads of bolt or nut.
i just use PB blaster. but some folks on here run a special mix of stuff, that eats paint, eats rust, and loosen stuff up.
   / 8N Pto Leak
Thanks Ryan,
Looking for a few more opinions please, has any one heated up the casing prior to trying to loosen the bolts?
   / 8N Pto Leak #4
They don't call a torch set the Big Red Wrench for nothing. Heating to break lose bolts works.
I'll usually get the bolt/nut glowing than hit it one more time PB blaster to hope the metal expansion allowed a little better penetration than give it try. I've tried using a propane torch but never had much luck with that as compared to oxy/acetylene. MAPP gas might perform a little better than propane if all you have is just a hand torch.
I allow the bolt to lose its red glow before torquing on it. While I like how an impact hammers to break it loose I don't like how there is no "feel" to know whether the bolt is going to break or not. Usually I will use a 1/2" cheater bar that is about 24" inches.
   / 8N Pto Leak
I am happy to report after a week of spraying with pbblaster, slow creep and wd 40 all bolts came loose easily with 6pt and a breaker bar! Thanks all
   / 8N Pto Leak
Next question went to drain all tranny rear end fluid on 8 n and there are 2 drain plugs on the bottom one under shifter/tranny and the other under the rear diff, which one(s) do I use to drain all hyd. Oil?
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
