mbryant51375
Recently my uncle and I took on the project of a 8n which had been sitting for several years while the tractor had not been stored properly we do know it ran great up till the electronic ignition had fried.
First we replaced the fuel tank, petcock and fuel line. The carb, which was a aluminum aftermarket version, was soaked thoroughly and rebuilt. We relaced the complete ignition system with new points setup, coil, ballast resistor, wires and plugs. The flyballs in the governor was also replaced. We also have replaced the intake gasket.
Now the tractor starts and idles perfect but will consistently hesitate or missfire once the throttle is adjusted to half throttle or above. We have taken the tractor to the only shop in our area but only to confirm the points was set correctly and the carb was adjusted, but the guy did not like the aftermarket carb so he set us up with the cast iron Marvel carb which I also put a kit in only to run exactly the same. Occasionally the tractor will act as if it wants to run correctly but then goes right back to hesitating.
