90 degree log lift with 8" stroke cylinder ???
   / 90 degree log lift with 8" stroke cylinder ???
Update...I've finished 98% of the fabrication and installation of the log lift a couple of weeks ago...after deciding to use a larger/longer stroke cylinder (that I had on hand, originally intended to raise/lower a 7' sickle bar)...it was fairly simple (after one or two boo-boo corrections...!)
But having to deal with some unforeseen hydraulic issues getting a two spool valve to work I have just today got to actually test the log lift:
I lifted about a 75# round without any movement but I have some rounds that are close to 300#'s !
...Ooo and another thing you might consider is a removable stabilizer leg so that when you lift the heavy ones the splitter doesn't tip over ...
I am concerned about this and will be looking at adding some bracing or even some anchors...
Eventually this entire setup...splitter, lift etc...will sit on a mobile base (trailer) and be self contained for hydraulics...may even make it more of a processor...already have a small knuckle boom in the design/material accumulation stage...just have so much other stuff going on...!
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
