928F Cat loader
   / 928F Cat loader #1
spurs
Hello everyone , need ideas to help with problem with loader steering. The Hydralics work good on everything else but the steering. It is real hard to steer .we changed out the check valve on the steering gear and it seemed to help a little but still hard. Could it be in the steering gear box? Just wondering if anybody else has had this type of problem before. Full of fluid and new filters. Please help thanks .
   / 928F Cat loader #3
did you try bleeding the system,maybe air in the lines
   / 928F Cat loader
We will try that, also found out the over fillrd Hydralic fluid all the way to top of filler could that cause a problem with steering?
   / 928F Cat loader #5
In my manual they tell you can go about a inch over full on the dipstick to allow working on slopes.
   / 928F Cat loader
They had this tractor filled to the top of the filler, when I took the top off it was over flowing.
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2' Auger Extension (A50774)
2' Auger Extension...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
