955 FEL lever sloppy
   / 955 FEL lever sloppy #1
Acehardly
Bronze Member
Amissville, Va
L & G 345, X595, 2305, 955 W/FEL
Hi again, I got to using my new to me 955 and I have noticed that the FEL lever is very sloppy. I looked it up on JDparts and it looks like a pretty simple setup. I would like to know if you think the pivot shaft is worn or if it could be just the shoulder bolt. Also, Seems like this is aweful sloppy for a tractor with 636 hours.
Thanks...Tony
   / 955 FEL lever sloppy #2
You'll have to take it apart to see.
jb
   / 955 FEL lever sloppy #3
Even my joystick on my 4110 is sloppy to me, been that way since new. Could be just looser than you like and not a real "problem", but you will have to take it apart to find out-pretty simple as you saw in the diagram.
Yeah, I will check it out. I think it is maybe a bit more than usual because I have to lean to the left so lift high enough.
I will let you know.
Tony
   / 955 FEL lever sloppy #5
My 5103 was also. Here is most likely the fix. Slid the boot forward on the joystick. You most likely will see 3 allen bolts. One of mine was loose. You might remove the bolts one at a time and apply a little "lock tight" on them and replace. I just tightned mine up and if it gets loose again I'll lock tight them.
Metal Firepit (A53316)
ALLISON TRANSMISSION (A55745)
ALLISON...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55302)
2021 John Deere...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
2021 FREIGHTLINER PX11664ST TANDEM AXLE DAY CAB (A56129)
2021 FREIGHTLINER...
