Morning!!!
My Kubota L355SS with Kubota 1200 loader has been losing hydraulic power for a long while now. I have to rev it high to get any pressure. I finally started pulling hoses & testing cylinders & the loader valve.
Results: I pulled a hose coming from the 1st position on the 2 spool valve. When actuated, it flows a steady stream out the same hose in BOTH positions, which I believe is BAD!
When I pulled the hose from the 2nd position of the 2 spool valve, it only flows when I move the lever in 1 direction, which I believe is normal.
Am I wrong / missing something?
I don't know the exact specs of the loader valve. I Believe it is about 8gpm, 1/2" In/Out, 3/8" work ports, Open center? I googled the number on the Victor DV 23 FA TS 006 loader valve, but didn't find anything. The loader valve utilizes the tractor's main hydraulic system, not a separate system running off of a 2nd belt driven pump.
2 big questions -
1. I believe the loader valve feeds back to into the hydraulic system at high pressure. It does Not return to tank. The feed/return come from a location between the 3pt lift & the pressure relief valve.
So, do I need anything different for a new valve that does not feed back to the tank, like power beyond? Or am I worrying about nothing?
2. While not needed, would now be the time to upgrade to 3 spool & plug it off until needed? (3pt log splitter, brush grapple, etc).
3. Is there anything else I should be concerned with?
Thanks guys!
2 big questions -
Thanks guys!
