9N steering
   / 9N steering #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
My Dad has a 9N. Runs good, but the steering aint good. The front tires will flop around enough, that they will toe-out too much to drive it. It looks to me, that the issue is with the steering arms where they come out of the "steering box". It is almost like one of the sectors jumped a tooth or something.
Any idea how hard, or expensive this would be to fix?
   / 9N steering #2
Are you sure it isn't excessive play in the drag links?
   / 9N steering
The tie rod ends are tight. It seems more steering box related.
I had hoped to look at it today(it's 35 miles away), but got postponed. Hopefully Thursday.
   / 9N steering #4
as you know, the 9n/2n has a completely different steering setup than the 8n.
if one of your side arm gears has jumped on the steering gear.. then you are in for pulling the trsanny top as that is apart of the stering box
still.. at this point.. you have not much choice.
here's a parts list to go with the diagram:
1 4 9N3517 BUSHING Bushing, Steering Gear Sector & Pitman Shaft, Half Round, Years: 01/01/1939-12/31/1947
2 1 9N3525 SHAFT Shaft Assy., Steering, Years: 01/01/1939-12/31/1947
3 1 PL PROCURE LOCALLY Washer, Lock, 13/16", Years: 01/01/1939-12/31/1947
4 2 PL PROCURE LOCALLY Nut, Hex, Steering Post, 13/16"-28, Years: 01/01/1939-12/31/1947
5 1 9N3526 Sector, Steering Gear, RH, Years: 01/01/1939-12/31/1947
6 1 9N3527 Sector, Steering Gear, LH, Years: 01/01/1939-12/31/1947
7 1 9N3540 Shaft, Steering Gear, Sector or Pitman, Years: 01/01/1939-12/31/1947
8 AR 9N3543A THRUST WASHER Washer, Thrust, Steering Sector, Outer, .122" Thick, Years: 01/01/1939-12/31/1947
8 AR 9N3543B THRUST WASHER Washer, Thrust, Steering Sector, Outer, .124" Thick, Years: 01/01/1939-12/31/1947
8 AR 9N3543C THRUST WASHER Washer, Thrust, Steering Sector, Outer, .126" Thick, Years: 01/01/1939-12/31/1947
9 1 NLS No Longer Serviced Housing Assy., Steering Gear, Lower, Used W/9N3551E Housing, 9N, Years: 01/01/1939-12/31/1947
9 1 NLS No Longer Serviced Housing Assy., Steering Gear, Lower, Used W/9N-3551-D Housing, Years: 01/01/1939-12/31/1947
10 1 PL PROCURE LOCALLY Plug, Expansion, 5/16", Years: 01/01/1939-12/31/1947
11 6 PL PROCURE LOCALLY Bolt, HH, 7/16"-14 x 1.50", Years: 01/01/1939-12/31/1947
12 1 NLS No Longer Serviced Cover, Steering Gear Housing, Upper, Used W/9N-3550-C, Years: 01/01/1939-12/31/1947
12 1 NLS No Longer Serviced Cover, Steering Gear Housing, Upper, Used W/9N3550A, 9N, Years: 01/01/1939-12/31/1947
13 4 PL PROCURE LOCALLY Bolt, HH, Upper to Lower Housing, 7/16"-14 x 1.12", Years: 01/01/1939-12/31/1947
14 2 B3552 CUP Cup, Steering Gear, Thrust Bearing, Years: 01/01/1939-12/31/1947
15 AR 9N3563A THRUST WASHER Washer, Thrust, Steering Sector, Inner, .255" Thick, Years: 01/01/1939-12/31/1947
15 AR 9N3563B THRUST WASHER Washer, Thrust, Steering Sector, Inner, .250" Thick, Years: 01/01/1939-12/31/1947
15 AR NLS No Longer Serviced Washer, Thrust, Steering Sector, Inner, .245" Thick, Years: 01/01/1939-12/31/1947
16 2 683571A BALL BEARING Bearing, Thrust, Steering Gear Worm, Years: 01/01/1939-12/31/1947
17 2 9N3573 BEARING CONE Cone, Steering Column, Years: 01/01/1939-12/31/1947
18 1 9N3593B GASKET Shim, Steering Gear Housing, End Cover, Gasket to Lower Steering Housing, Rear, Years: 01/01/1939-12/31/1947
19 1 9N3594 SHIM Shim, Steering Gear Housing, End Cover, Gasket, Upper to Lower Steering Housing, Front, Years: 01/01/1939-12/31/1947
20 1 E0NN3600AA STEERING WHEEL Wheel Assy., Steering, Years: 01/01/1939-12/31/1947
21 1 351103S8 NUT Nut, Hex, Steering Wheel to Shaft, 5/8"-18, Years: 01/01/1939-12/31/1947
22 1 74148S WOODRUFF KEY Key, Steering Wheel to Steering Gear Shaft, Years: 01/01/1939-12/31/1947
23 1 9N3660 Seal, Steering Column, Dust, Years: 01/01/1939-12/31/1947
24 1 9N3661 RETAINER Retainer, Steering Column, Dust Seal, Years: 01/01/1939-12/31/1947
25 1 PL PROCURE LOCALLY Cap, Steering Wheel, Used W/9N3600B Only, 9N, Years: 01/01/1939-12/31/1947
25 1 9N3669 Cap Assy., Steering Column, Years: 01/01/1939-12/31/1947
26 1 PL PROCURE LOCALLY Fitting, Lube, Steering Column Cap, 1/4"-28, Years: 01/01/1939-12/31/1947
27 4 9N3670 Packing, Steering Gear, Sector Shaft, Years: 01/01/1939-12/31/1947
28 1 2N3673 WASHER Washer, Steering Wheel, Years: 01/01/1939-12/31/1947
29 1 9N3699 Spring, Bearing, Steering Column, Years: 01/01/1939-12/31/1947
30 1 9N7010 PLUG Plug or Cap, Transmission Filler, Years: 01/01/1939-12/31/1947
31 1 8N7011 GASKET Gasket, Plug, Transmission Filler, Years: 01/01/1939-12/31/1947
32 1 9N7223A GASKET Gasket, Gearshift Cover, 8 Holes Oblong, 17.80 Long x .020/.022" Thick, Used On & BSN 47508, Years: 01/01/1939-12/31/1942
32 1 9N7223B GASKET Gasket, Gearshift Cover, 6 Holes Oblong, 17.80 Lg. x .020/.030 Thick, Used On & ASN 47507 * No Longer Serviced, Years: 01/01/1943-12/31/1947
33 1 8N3679C IGNITION SWITCH Lock & Wire Assy., Ignition, W/2 Keys, Includes: Ref. 34 & 35, Years: 01/01/1939-12/31/1947
34 1 PL PROCURE LOCALLY Nut, Hex, Lock to Housing, 1-3/16"-20, Years: 01/01/1939-12/31/1947
35 2 9N3685B KEY Key, Ignition, Universal Series 1053, Years: 01/01/1939-12/31/1947
36 1 9828014 KNOB Knob, Choke, Years: 01/01/1939-12/31/1947
37 1 9N9805 ROD Lever, Throttle Control, Years: 01/01/1939-12/31/1947
38 1 PL PROCURE LOCALLY Spring, Lever, Years: 01/01/1939-12/31/1947
39 1 9N9807 Arm Assy., Throttle Control, Years: 01/01/1939-12/31/1947
40 1 PL PROCURE LOCALLY Retainer, Lever Spring, Years: 01/01/1939-12/31/1947
41 1 9N9819A Pin, Control Lever to Control Rod, Used W/9N9805, Years: 01/01/1939-12/31/1947
42 1 NLS No Longer Serviced Panel Assy., Instrument, Used W/9N-3551-D, Years: 01/01/1939-12/31/1947
43 6 PL PROCURE LOCALLY Washer, Lock, 5/16", Years: 01/01/1939-12/31/1947
44 2 PL PROCURE LOCALLY Bolt, Hex, 5/16"-18 x .56, Years: 01/01/1939-12/31/1947
45 1 PL PROCURE LOCALLY Plug, Light Switch Hole, 3/8", Years: 01/01/1939-12/31/1947
46 2 355471S8 Bolt, Carriage, 5/16"-24 x .75, Years: 01/01/1939-12/31/1947
47 6 PL PROCURE LOCALLY Nut, Hex, 5/16"-24, Years: 01/01/1939-12/31/1947
48 2 PL PROCURE LOCALLY Bolt, Hex, 5/16"-24 x 1", Years: 01/01/1939-12/31/1947
49 1 9N9700A ROD Rod Assy., Choke Control, Used W/Battery Ignition, Not illustrated, Years: 01/01/1939-12/31/1947
50 1 9N9810 SOCKET Socket, 3" Long, Throttle Control Rod Assy., Not illustrated
   / 9N steering
Guessing that would be the case.
Aint no good with no steering(the tires move around too much to drive it, besides maybe on my trailer.
   / 9N steering #6
good luck.
aside from the inconvienience of pulling the trans top.. it's a pretty cut and chase clean steering system. not much room for wear though.. ie.. not many adjustments. thus parts replacement will be neede dif something is excessively worn.
soundguy
2011 Freightliner Cascadia 113 S/A Day Cab Truck Tractor (A59230)
2011 Freightliner...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
Towable Dewatering Pump (A59228)
Towable Dewatering...
159116 (A60430)
159116 (A60430)
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
(32) 8" FLOOR TRUSSES (A60432)
(32) 8" FLOOR...
