A big TBN thank-you...
   / A big TBN thank-you... #1
ljh2
Western Maryland
Kubota M6800, Ferris IS4500Z Cat Diesel mower
I just wanted to pass on a big THANK YOU to our host Muhammad and all of the members that post their experiences on TBN. Some of you might remember me from a time when I was more active here... other newer members probably not. Things have been so busy around my life lately that I haven't taken much time for TBN.
Well anyway to get to the point, during a recent tractoring session on my Kubota M6800 w/LA1162SL loader where I was pushing out a bunch of overgrown multi-flora rose bushes, my loader's float-detent stopped working. :eek:
At first thought I figured that something had gotten jammed into the linkages or such, but upon inspection of the valve-spool everything looked OK. So I pull out the owner's manual which after reviewing every page told me absolutely nothing. I don't even recall seeing ANY sort of troubleshooting section. :(
So I pull out the computer and login to TBN and do a quick search for 'loader joystick float detent' and come up with a bunch of threads -- several of which had helpful suggestions to their originators regarding problems with their float-detents. A couple of the posts talked about removing the 'cover-nut' on the bottom of the spool (below the lift valve) and finding water there that kept the valve from reaching the detent position. I went out an opened mine up and sure-enough there was water in the cap. I dumped that out and lubed it up with some grease and woohoo now it works like new again.
Thanks to you guys on TBN, I managed to save not only the $$$ of having the dealer look at it, but I avoided the downtime of having my tractor sitting in the shop. :)
Anyway, while I don't get around to TBN as much as I once did, I'm still thankful that we all have this great place to share our experiences and knowledge.
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
Toro Mower (A50324)
Toro Mower (A50324)
JOHN DEERE LOT IDENTIFIER 154 (A53084)
JOHN DEERE LOT...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
