A 'nudder Tiller question (for BX1500)
   / A 'nudder Tiller question (for BX1500) #1
herder_of_cats
Earlysville Va
BX 1500
Has anyone had any experience (good, I hope) in using a 3pt tiller on a BX1500? I'm getting conflicting information from a number of dealers.
I was thinking of a 48" from TSC possibly.
Thanks in advance!
   / A 'nudder Tiller question (for BX1500) #2
I have one for my BX1500. Dealer sold it to me at time of purchase. I think it is 42". Just used it 2 weeks ago on a large garden area that was pretty dense soil with a lot of small rocks and had no problems.
   / A 'nudder Tiller question (for BX1500) #3
Just checked. It is a BEFCO T30 42" tiller. Their manual says it is for subs up to 30 HP.
Thanks for the information. I had not thought of a Befco.
Just out of curiosity, what type of soil do you have? I'm going to use the tiller on old pastureland that has more than a few rocks.
Thanks,
mark
   / A 'nudder Tiller question (for BX1500) #5
I live in central Virginia and calling what I have soil is being kind. What I have here is clay and it gets hard. The area I am tilling use to be pine woods that I had cleared. I dug up alot of old roots and lots of rocks. Only broke a shear bolt once though. Just have to clear up after a few passes.
Thanks again.
You're in central VA? I'll be tilling in Bedford county near Huddleston. You close by?
mark
   / A 'nudder Tiller question (for BX1500) #7
Mark,
I am in Albemarle, out near the Fluvanna line. Four miles from Lake Monticello.
Bob
   / A 'nudder Tiller question (for BX1500) #8
You should be fine with any tiller up to 48" in width designed to fit a subcompact. I'd even bet that most tillers that size will fit a BX even if they weren't specifically designed for a limited Cat.1 hitch.
And, I'll repeat what I've said many times before... BX's have PLENTY of horsepower for their size, even the 1500 model. You will run out of traction LONG before you run out of power.
Even if the going gets tough there are things you can do to maximize your power utilization:
1. Reduce your forward speed. It shifts more power to the PTO (because less of the available power is going towards propultion) and at the same time relieves some of the load on the PTO because the tiller is taking smaller bites.
2. Take less-than-full-width passes. You are effectively reducing the width of the tiller by subjecting only a portion of it to hard soil. The rest is just re-tilling soil that has already been broken up.
3. Make multiple passes. Go shallow at first, then work deeper.
4. Dampen the soil first to soften it up. Wait until after a light rain or set a sprinkler on the area. But let it dry out a little before you get started so you don't get stuck.
Obviously these suggestions don't apply to a big operation, but for the homeowner and hobby-farmer it makes a lot more sence than spending thousands $$$ on a bigger tractor that you really don't need.
Thanks for the info Ace! You pointed out a couple of things I had not thought of. I agree that the tractor runs out of traction before it runs out of power. I am amazed at how much these tractors can do!
Now to convince "She Who Must Be Obeyed"! ;)
My brother-in-law drove my 'bota for around an hour and was so impressed with it, he is in the process of buying a small one for his place.
Thanks for everything!
mark
2012 Ford F-450 XLT (A50120)
2012 Ford F-450...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
Deere 331G (A50120)
Deere 331G (A50120)
