A quick check on something
   / A quick check on something #1
dustinfox
New Hampshire
Kioti CK35 HST
Hi folks... Spring is coming and the tractor is out of the barn! I just want to do a quick check on a delivery I have coming tomorrow....
Kioti CK35HST with 42" pallet forks from Titan skidsteer. My delivery weighs in at almost 1400 lbs. I've never actually weighed anything that I moved with this setup but will I be OK offloading this pallet from the delivery truck? I think the pallet forks themselves weigh around 300 lbs.
   / A quick check on something #2
Front Loader Lift Capacity
The Kioti CK35HST can lift up to 1,764 lbs at a distance of 24" from the lift point. Do you have ballast in your rear tires?
Dennis
   / A quick check on something #3
Hang the heaviest implement you have off the three point, as much as you can to get to about 900 lbs or so
Thanks guys... I do have ballast in the tires and am hanging a 60 inch box blade off the back. I should be fine then!
   / A quick check on something #5
Do you have a rotary cutter? That would be better in most cases.
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
UNUSED Single Stall Portable Restroom (A53117)
UNUSED Single...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
