A Vintage Sound
   / A Vintage Sound #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
For all you JD fans!
   / A Vintage Sound #2
Thanks, that is a very memorable sound. GP, hand start model A, A, AR, H, B, G, - all etched in my history.
   / A Vintage Sound #3
Mike, It reminds me of the simpler days gone by. Brings back alot of memories.
_____________________________
Take care, Jim
   / A Vintage Sound #4
Great! Now where can I find the poom-poom-poom of a JD 420?
   / A Vintage Sound
Is this the sound?
   / A Vintage Sound #6
nope - that sounds more like a hit-n-miss engine
   / A Vintage Sound
I'm runnin' outta sound files /w3tcompact/icons/smile.gif. How about this?
   / A Vintage Sound #8
Just to clarify, and maybe help MikePA, is the JD420 you speak of the 50's 2cyl upright engine (Dubuque, IA) (that was not the 2cyl horizontal that MikePA first attached)? The description poom-poom-poom isn't the one that was descriptive of my JD420 utility ('58), but I can't write a better one down. The upright 2cyl was a higher rpm than the horizontal ones, and had ~4" holes instead of 5+" holes. The sound that MikePA first came up with for your description sounded like two engines, one steady 4cyl in the background and a hit-n-miss in the foreground. Or the background was the mechanical linkages on the hit-n-miss. (There is a GT JD420 but I am sure that is not the one you refer to in your post)
   / A Vintage Sound #9
nope! (That one sounded too smooth). Don't worry - I'll figure it out at some point. BTW - it WAS a vertical 2 cylinder engine.
   / A Vintage Sound #10
Do you have any of the larger diesels like in the R?
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
KOOMEY INC VALVE ACTUATOR (A52472)
KOOMEY INC VALVE...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A52748)
2021 NEW HOLLAND...
