add plate to 3 pt lift arms
   / add plate to 3 pt lift arms #1
Jrasband
Platinum Member
Southwest VA
Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
Hey I replaced the lift arms on my LS XG3032 with the standard ones they sell at Tractor Supply because I needed a longer arm
The new arms have been a big improvement although I just noticed one of the arms has a slight bend in it.
I want to weld some 1/4" plate to the lift arms. I can fit a 1/4" between the vertical lift arm mount. There is 24" between the cast ends so I was thinking of cutting the pieces around 23 1/2" and laying the bead right next to and on the factory one. I was told they are made from spring steel, not sure how that would make any difference? Would you weld all the way around or just stitch weld?
Maybe I am over thinking this but wanted to see if anyone had any useful info to offer, thanks.
   / add plate to 3 pt lift arms #2
post a pic of the arms ,, yhat you want to weld on .
   / add plate to 3 pt lift arms #3
might run a length of angle iron, doubt if spring steel but maybe some extra carbon versus cold rolled. no expert
ATTENTION! PLEASE READ (A44502)
ATTENTION! PLEASE...
2019 Club Car 2-Seater Golf Cart (A44391)
2019 Club Car...
Rears 1000 Gallon Orchard Sprayer (A44501)
Rears 1000 Gallon...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A43003)
1993 INTERNATIONAL...
2016 GMC Terrain SLE2 SUV (A44572)
2016 GMC Terrain...
Whiskey Barrel (A44391)
Whiskey Barrel...
