Added a sunshade for TS this morning
   / Added a sunshade for TS this morning #1
Timber
Veteran Member
East Bridgewater Massachusetts
Kubota B7800
   / Added a sunshade for TS this morning #3
Looks great. Really like that. Can you tell me where you got it or what brand it is? I would like a shade like that which curls down the side.
Thanks!
Thanks!
I picked it up at tractor supply for less than $150
   / Added a sunshade for TS this morning #5
Thanks!
I'll take some close up pictures this morning to show you how I mounted it. It is designed to be mounted with or without a ROPs. Mine was foldable and had a bracket with predrilled holes that made it a very simple installation.
Thanks!
Snowco is the company that distributes this item. It is a universal sunshade and the design is such that I believe it can be mounted on anything. I mounted mine on the roll bar but their are instructions to fender mount it if want. The instruction are very vague at best.
What I did was fold the ROPs down and it exposed the top hole in the hinge plate on the roll bar. The bottom hole is in front of the lower 1/2 of the roll bar but I could slip the wrench and nut up between the 2 and fasten the lower bracket. To top bracket I put through the back side with the fender washer provided. The entire installation took about 30 minutes
I went out and cut my neighbors field to try out the new top in pure sun. It worked out well but my knees got a little burnt. I over heated the tractor a bit. Seems I filled the radator and grill screen with grass seed.
   / Added a sunshade for TS this morning #9
Good looking installation.
Charlie
   / Added a sunshade for TS this morning #10
That looks really nice and a great price. However it's lifespan on my tractor would be about 15 min before a tree reached out it's paw and destroyed it. I was able to explode the original ABS one....now I have steel:thumbsup:
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
2020 John Deere 260E 26 Ton Articulating Off-Road T/A Dump Truck (A50322)
2020 John Deere...
2001 Ford F150 (A50121)
2001 Ford F150...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
