DaveNay
Platinum Member
- Joined
- Aug 13, 2003
- Messages
- 834
- Location
- Waterman, DeKalb County, Illinois
- Tractor
- John Deere 855 MFWD; Oliver 1850 Gas
I would like to add some gauges to my JD855. Primarily, I am going to add a water temperature gauge, because I can't stand having just the indicator light that suddenly pops on at a given temp. I am also considering adding the following.
<ul type="square"> [*]Engine Oil Temp [*]Engine Oil Pressure [*]Hydraulic Temp [*]Hydraulic Pressure [/list] The water temp gauge is easy, I can just replace the existing sensor, but where do the other sensors go? I am figuring that I can use engine oil temp/pressure gauges for the hydraulics, not needing anything special. Could the hydraulic temp probe go into one of the case drain plugs in the transmission? I would like to make sure I place the sensors on the best location to get accurate readings.
Oh yeah.....why add the gauges? Because I want to! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
Dave
Dave
