Chipper Adding hydraulic feed to Wallenstein chipper
   / Adding hydraulic feed to Wallenstein chipper #1
Massey1010
Willamette Valley
I have a self feeding Wallenstein BX62. I was wondering if it is possible to add an automatic feed to this unit?
   / Adding hydraulic feed to Wallenstein chipper #2
Yes. It's easy to do, but a little spendy. I was quoted around $2100. more for hydraulic feed:eek:. To me, it's been worth it. All the hydraulics are mounted on the feed hopper, which is attached to the chipper housing with 2 bolts, just like the self feed models. As you probably know, the hydraulics are run from the remotes on the tractor. The flow control lever is located on the main valve body, which allows the dual feed rollers to turn at infinitely variable speeds. On my BX42, the hyd. hopper added about 200 lbs., making it 625 lbs. I would imagine the additional weight on your BX62 would be similar.....Dan.
   / Adding hydraulic feed to Wallenstein chipper #3
What Dan said.......... the difference is all in the hopper, which is a bolt-on operation. When I was pricing it out, I think I was quoted about $2500 for the change-over. But, $2100 ....... $2500, what;s the difference.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
