Adding hydraulic to MF35 Special
   / Adding hydraulic to MF35 Special #1
TennFire
MF35 - gas - good operational condition but would like to add hydraulics to power some accessories. Most of current use involves a box blade and field mower.
I like the tractor size and weight because it tows well on a 16 foot trailer and all of my use requires approximately 1 hour drives. I am not sure I want to sell (this was wife's grandfather's tractor) to just get hydraulics.
What options are there to add hydraulics? I have seen the kit on Ebay that sells for just under $300 to take power from the 3 point but it has its disadvantages.
   / Adding hydraulic to MF35 Special #2
There is a valve available that replaces the small plate just under the right front corner of the seat. That is where you access the hydraulic power on your tractor. If any of your implements using the auxiliary hydraulics is mounted on the 3 point hitch, it is very difficult to use this hydraulic power. But if the equipment is pull type then it can be used effectively. Your other option is to install a separate hydraulic system on your tractor using a front mounted hydraulic pump driven off the crankshaft of the engine.
</font><font color="blue" class="small">( There is a valve available that replaces the small plate just under the right front corner of the seat. That is where you access the hydraulic power on your tractor. If any of your implements using the auxiliary hydraulics is mounted on the 3 point hitch, it is very difficult to use this hydraulic power. But if the equipment is pull type then it can be used effectively. Your other option is to install a separate hydraulic system on your tractor using a front mounted hydraulic pump driven off the crankshaft of the engine. )</font>
I have seen the auxiliary adapter from time to time on ebay for about $300. I was looking at other options such as running a pump off of the engine, a PTO pump or even a 12VDC unit.
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
