CTyler
Veteran Member
I have a pole building that was insulated when it was built. The insulation is fiberglass with a white reflective(?)backing. Not really sure if it has a reflective value for insulating vs just reflecting light better.
I framed off a 50x16x8h area that is to be finished. There is a utility room with a toilet, shower, laundry. I want to add additional insulation to this whole area.
The part that has me concerned is the existing white backing/reflective layer on the outside walls. The vapor barrier should be to the warm side of the building(inside). By adding additional insulation this will place that layer in the middle vs the inside. Do I place some slits in it and add a new vapor barrier or just add insulation? I don't want to trap moisture and cause problems down the road.
I'm making the assumption that the backing is indeed acting as the vapor barrier.
Chris
Chris
