disney
- Joined
- Aug 11, 2012
- Messages
- 378
- Location
- orlando fl
- Tractor
- scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Hello. I would like to add rear remotes, mostly for 'TnT' use, and would like to hear ideas for what types of spools/ valves to add. I only know enough to get me in trouble... I assume all would be/should be double acting? I plan/would like to add three sets, two for TnT, and one 'extra'.
Should the first two pairs have the floating feature? (Would much rather spend a few extra $, than forever more say "I wish I had....")
Should the 3rd set have "three position mechanical detent? Question on how that operates; With the 3 position detent spool; say I am using it to angle a power angle rear blade/rake, can/could I go from center detent (off/ hold position?) to say the left detent, allow the blade to move to the desired position (but not the cylinder's max travel), and then bump/push the level back to the center position, would the blade/rake then be held in its current position?
The tractor has a power beyond 'loop' one hose with a fixed/non-removing end and a quick coupler/receiver on the other end. Pump/type is open center and rated flow (at power beyond) is 16.x gpm at 3000psi, so do I need an 'open center valve with inlet relief', or 'an open center valve with inlet relief and power beyond'? Not sure I understand the difference since an open center system has to have a main inlet and a main outlet right?
Any good reason to even consider a motor type spool?
What is the feedback feel like on say the prince brand level control valves?
Thank you to all who help, and may everyone have a safe and happy new year!
