adding stability
   / adding stability #1
Mtsoxfan
Platinum Member
Newark Vermont
Kioti 3520SEH Holland TC29D
I'm looking to make my NH TC29D HST more stable on sloped land. I would just be brush hogging twice a year or so, currently an old 10 acre hay field, but mowing parts of it to use as walking paths. I currently have a FEL on, wheel weights and while "cruising" a piece of property I'm looking to buy, it felt very unstable on the sloped terrain. Felt like I was going to tip over at times. I ran my lawn tractor over the same area I drove the tractor, still felt like tipping over. A new to me tractor isn't in the cards, although this posts reponses may lead me to that. That purchase would be a year or two out. Trying to make the most of what I have.
I was thinking wheel spacers, but didn't want to research until I heard back from some of you. I'd rather not take off FEL unless it was key to stability, back issues, although it looks pretty straight forward. Would a 2wd tractor with a wider stance make more sense? What should I be considering? Just buying to maintain lack of neighbors and the view.
Thanks all...
   / adding stability #2
Thanks all...
I have a hill that I mow that used to give me that similiar feel of tipping. All it takes is one hole you may not see dug by an animal to cause a roll over.
Now I mow it up and down the slope, eliminating driving along the slope.
Takes a little bit more time, but it always feels safe. It is steep enough that I mow this section in 4x4 mode.
   / adding stability
Thanks. I did run in 4x4 to help maintain traction at all times. There are some areas where up/down isn't possible due to all the changing slopes. I've read, now going to confirm that I can swap tires side to side to give a wider stance as the rim plate isn't centered. I'd have to look to see if the weights will clear being on the inside. Thinking they won't, but worth a look. I'm guessing the weights are more important than the added width??
And I know from walking the area, there is at least 1 fox hole and groundhog holes to contend with.
   / adding stability
Just measured the rears, they are 60" outside to outside. If I reversed rims,inside to outside, right to left I would lose 1", so the rears are at their widest. The fronts are at 52". I could gain at least 6" with an inside to outside, left to right configuration swap. After reading an old post, the posted had issues with his 72" belly mower when he switched rims configuration. My belly mower is 60" and doesn't appear to be an issue. Can you think of any reason I wouldn't want to widen the stance up front?
   / adding stability #5
Your minimum turning circle will be wider, with wider spread front wheels.
When you spread front wheels, stability changes depending on the angle of the front axle. Much better to spread the rear wheels.
No.
   / adding stability
Thank you. That I can deal with. Even cutting my lawn I get that uneasy feeling. Not as bad as adjoining property I want to buy though...
   / adding stability #7
New Holland TC29​
New Holland TC29 tractor photo
1999 - 2003
Boomer TC Series
Compact Utility tractor
Variants
TC29gear
TC29Dhydrostatic
New Holland TC29 Power
Engine (gross)29 hp
21.6 kW
Engine (net)27.4 hp
20.4 kW
Gear PTO (claimed)25 hp
18.6 kW
Hydro PTO (claimed)23.6 hp
17.6 kW
New Holland TC29 Weight
2WD Shipping2,474 lbs
1122 kg
4WD Shipping2,474 lbs
1122 kg
SuperSteer Shipping2,588 lbs
1173 kg
   / adding stability #8
Your best approach is to add wheel spacers to your rear wheels.
Bro-Tec is the supplier in Canada I use in Florida. Bro-Tec's wheel spacers are industrial art.
Ventrac - TBN ARCHIVE:
Ventrac - YouTube Videos
   / adding stability
Thanks, I will check them out. I have BORA's on my Ranger, love how they changed the handling/look. Top of the line materials.
   / adding stability #10
I do not believe Bora produces any wheel spacers which Bora markets to the tractor segment.
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
CASE 580M TURBO BACKHOE (A51242)
CASE 580M TURBO...
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
