Adding "the Thumb" to a Kubota B1750 with a B1640a Loader
   / Adding "the Thumb" to a Kubota B1750 with a B1640a Loader #1
Wasmeneh
I am trying to figure out what I need to add "The Thumb" to the above tractor. It was suggested by customer service that a diverter valve from surplus center, part # 9-8602 would be an easy way to add the Thumb. I have never messed with hydraulics other than replacing hoses so forgive me if these are simple questions. The tractor is about 1 1/2 hours away but I'm going up soon to do more cleanup from Florence. I am tires of tying branches onto the FEL to move them.
My assumption is that the valve connects to the tilt function on my FEL control but it would seem to me that I need two short connection pieces to accomplish this. I am trying now to figure out how and what parts I would need to connect this diverter valve to the current valve on my tractor. I emailed a question to the surplus center but so far no response. I am also interested as what would be a good electric momentary switch to use. I will source the hoses locally probably unless there is major savings somewhere else.
Thanks in advance
Mike
Wilmington, NC
Thanks that helps. Looking for the connectors to P1 and P2 I think. All other conections should be regular hoses. Does that sound right?
   / Adding "the Thumb" to a Kubota B1750 with a B1640a Loader #4
The Surplus Center valve cited in the first post uses SAE (o-ring boss) connectors...SAE to NTP (tapered pipe) adapters are available or hoses can be ordered with SAE ends...
one of the first things required for DIY hydraulics is learning the different type and size nomenclature for the different sizes and port connections, fittings etc...many small tractors use JIC (flare) connectors especially on the cylinders etc...
here is a link to a free guide from a great source for hoses and fittings etc...(faster service and shipping than S.C.)... http://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
