Adjust Rear Tread Width?????
   / Adjust Rear Tread Width????? #1
bill18163
NW Pennsylvania
Kubota B2710,BX1860,LA3940
I just bought a new L3940. On page 75 of the manual for the tractor it reads "Rear tread width can be adjusted as shown with the standard equipped tires." It goes on to say how to do it. I have not gone out and looked at the rear wheels yet to look this over and try to figure it out. Can someone explain this to me? Does this mean I can move the tires farther out in the wheel wells so I will have more room to put a set of chains on in the winter?
   / Adjust Rear Tread Width????? #2
If you have standard equiped tires (R1/ag) then yes.
I went back and looked at the page that shows this process and my L3940 with 17.5-24 Industrial tires lists three different widths:52.8"-54.3"-58.7". I went out and looked at the tractor and I can see how you could re-arange the rim and the disk either with the rim boss on the inside or the outside of the disk which would change the tread width. Right now my tires are set up with with the rim boss on the outside of the disk. So then I have to ask the question how do you manage to get the dimension of 58.7" in the last picture on page 75 of that manual. The picture is the same for the 52.8" configuration and the 58.7" configuration which has the rim boss on the outside of the disk. Or am I really missing something here? Something I'm not seeing or don't understand???
   / Adjust Rear Tread Width????? #4
The rim boss is offset, move the tires to the opposite side.
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2007 FELLA SM350 3 PT DISC MOWER (A53472)
2007 FELLA SM350 3...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
