Adjusting a Tiller driveline slip clutch
   / Adjusting a Tiller driveline slip clutch #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
How difficult is it to adjust a pto driveline slip clutch for a tiller? Can a novice non-mechanic handle this adjustment procedure? How often would this adjustment need to be done?
   / Adjusting a Tiller driveline slip clutch #2
I adjust mine annually in the spring. I back off all the nuts a couple of turns, drop the tiller into the dirt to make sure the clutch slips, (free up the winter corrosion). Then tighten things up a turn. If the clutch slips breaking new ground I'll tighten the nuts another half turn. A little trial and error, but it works for me. Too tight and the clutch will not slip and you'll break something, too loose and the clutch will be toast in no time.
The first year I had the tiller I tried to set the tension using a torgue wrench, but you need 1 that will go down to inch pounds. I do it be feel on both the brush hog and the tiller.
   / Adjusting a Tiller driveline slip clutch #3
the adjustment on mine is by the length of the springs,according to the hp of the tractor..i have a 42hp mahindra and the spring length is supposed to be 26.25mm,the more hp you have the shorter the springs should be..
   / Adjusting a Tiller driveline slip clutch #4
I guess I adjust my Howard the same as the others. Back off the nuts until the springs are loose, dig in and make it slip, tighten the nuts 4 flats ( 3/4 turn ) and try again. If it doesn't slip after the 4 flats on the nut tightening, I run it. I haven't hit anything that has caused the clutch to slip yet but I'm sure it will work when the time comes.
Chris
   / Adjusting a Tiller driveline slip clutch #5
Do a search using the words
Re: Slip clutch adjustment
Egon
   / Adjusting a Tiller driveline slip clutch #6
"the adjustment on mine is by the length of the springs,according to the hp of the tractor..i have a 42hp mahindra and the spring length is supposed to be 26.25mm,the more hp you have the shorter the springs should be."
That doesn't sound right to me. It seems to me the clutch should slip, (and save your equipment), or not, (and damage something), regardless of how much horsepower you have, and the spring tension should be determined by the clutch manufacturer. That would be like using a bigger, stronger shear pin, the more horse power you have.
   / Adjusting a Tiller driveline slip clutch #7
normde2001,those specs came from the owners manual for my tiller,and from experiance they will slip when they have to,say when you hit a rock,stump ect.i have a 72" WAC tiller
   / Adjusting a Tiller driveline slip clutch #8
Norm,
I would assume that the reason for the tighter clutch adjustments for a higher HP tractor would be to take into account the heavier duty PTO components in a higher HP tractor vs lighter duty ones in a lower HP tractor.
Ben
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
7046 (A50322)
7046 (A50322)
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
