Adjusting clutch
/ Adjusting clutch #1
twinjayhawks
NE of Tulsa, OK
Century 3045
Can anyone tell me how to adjust my clutch? It engages right at the very end of the pedal coming all the way out. I can just slightly push the clutch and the drive disengages. I am afraid that it is slipping right now when the pedal is all the way out.
/ Adjusting clutch #2
check your manual for the freeplay setting. that is how much you should be able to push the pedal before you encounter resistance.
if it is too tight / no or negative freeplay, you will wear the fingers as they will be in contact with the TO bearing constantly.
soundguy
/ Adjusting clutch #4
If you have the correct free play..... well you might need a new clutch.
Russell
/ Adjusting clutch #5
Look for the linkage connecting to your clutch pedal. Somewhere in that linkage - between the pedal and the place where the linkage connects to a shaft entering the bell housing - is an adjuster. Adjust that to give you freeplay at the top of your pedal travel. Around an inch play is good.
larry
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
208315 (A58376)
208315 (A58376)
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
