monster318
Hello,
A few weeks ago I picked up a small air compressor for my home garage at a flea market, dont really need it for much, due to having an 80 gallon two stage compressor 2 miles up the road at my shop, but its handy to have one just to blow out carb parts or inflate a tire here and there. The only problem with the compressor when I got it was the plastic line that runs from the tank to the cut off switch was broke off right at the cut off switch. After doing some research online and finding out that the current cut off switch model that I have was discontinued, I called Campbell Hausfeld and asked if there was anything I could do in this situation. The girl took my model and serial number of the compressor and found one that she said is comparable and would work so I ordered it directly from her.
It arrived the other day and I installed it last night. Ran the compressor and it worked great and shut off at 125psi. Then as I was wheeling the compressor back to its spot in my garage I see "100psi MAX" on the side of the tank of my compressor and also on top of the electric motor.
Do you think 25psi over is okay? or I noticed their is a phillips head screw on the top of the cut off switch labeled "pressure adjust" but it marked in such a way that they can tell if you tampered with it.
I am not sure if this is something the girl overlooked when telling me this cut off switch would work or if they know at the manufacture that there is kind of a "buffer zone" that within so many psi its acceptable to be over.
