Adjusting sway links on 3pt hitcht.
   / Adjusting sway links on 3pt hitcht. #1
TerryinMD
Veteran Member
Sharpsburg, Md
John Deere 4100 HST
Just finished performing my 50hr maintenance on my JD 4100. No problems. Issues yes!!!
I tried to adjust the sway links on my 3pt hitch and found out that it was basically useless. I have a MMM which has bracket to replace a shim on the sway link attaching point. There is one hole which limits the turnbuckle. The bottom links have been rubbing on my tires when I use my rotory tiller. So I wanted to tighten them up to prevent the tire/link rubbing problem.
The MMM bracket/arm installation looks okay. Any suggestions.
Terry
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
Shoreline Boat Trailer (A50860)
Shoreline Boat...
2022 Club Car...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
8 Ton Combo Pintle Hitch (A48081)
8 Ton Combo Pintle...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
