adjusting the clutch on my kubuta 245dt circa 2002
   / adjusting the clutch on my kubuta 245dt circa 2002 #1
dame edna
australia
kubota 245dt circa 1994
G'day everyone. When i change gear it always grates. The book say i adjust the gap between the clutch lever and the clutch bearing as seen thro' the little inspection hatch on the side of the engine. I've tried adjusting the clutch pedal rod long and short and it doesn't make any difference to the gap between the horseshoe lever and the protuberances on the side of the bearing housing against which the lever pushes. Is this the gap they mean 'cos it seems as this bearing is spring loaded there will never be a gap. Or is the gap [ 2.5 -3.0 mm ] further forward between the actual bearing race and the spinning clutch member. Why is car/ tractor mechanics so bloody double dutch to me?? And am I completely barking up the wrong tree anyway re. my grating gear changes. Any ideas would be bonzer. From down under Martin
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2008 Ford F-250...
(5) JOHN DEERE WEIGHTS & MOUNT (A52708)
(5) JOHN DEERE...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
Club Car Utility Cart (A55851)
Club Car Utility...
Miller Millermatic CP/CC-1500 Industrial Welder  Heavy-Duty Power Source (A59225)
Miller Millermatic...
