Snow Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #1
funwithahoe
I see a lot of questions about what to buy for snow removal so I thought this might be a good thread to start. I have owned all three and they all have their pluses and minuses - Feel free to tag on with your experience.
Advantages:
Scraper Blade
1) Easy to take on and off
2) Easy to leave the loader on so you can pile high
3) Cheap (by comparison)
4) You can use it in the summer for light grading (spreading the cost over multiple duties)
Blower
1) Throws snow far out of the way so you don't have to worry about piling too high.
2) Tractor traction not as much of an issue since you don't have to push
3) Usually can handle a deep snow well
Snow Plow
1) Hydralic angling makes life easy (compared to scraper blade)
2) Fast
3) "Shoes" allow you to keep the blade about 1/2 inch up off of a gravel driveway so you aren't pushing the gravel into your grass
4) "Trip" feature is easier on tractor and blade (Compared to scraper blade)
Disadvatages
Scraper Blade
1) When you hit something frozen (covered stump etc) something is either bending or stopping in a hurry.
2) Pushing backwards is not how a 3pt is designed so it is easy to bend arms
3) If you don't adjust correctly it will scrape the heck out of your driveway.
4) You are facing the wrong way which means you may soon have a new friend at the chiropractor's office
Blower
1) Slower
2) You miss the fun of pushing snow into a huge pile and then letting your kids climb up it:)
3) Lots of moving parts - More to break
4) Loves to throw gravel or atleast break the sheer pins throwing rocks
5) Some are tough to get on and off
6) Expensive
Plow
1) More $ than a scraper blade
2) No loader
3) With my B3200 I can only pile about 4 feet high
Feel free to add your own ideas.
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #2
thanks for your input...im in a quandary myself what to buy for my tractor. taking on alot more winter snow work than i have in the past.....getting a little nervous that ill buy the wrong equipment. i do love my rear push snowblower, and the shoes keep gravel intake to a minimum....but pretty slow going. my old plow is 60", the new one will be at least 84". should help some. front blades are a mystery to me...never used one before. I keep envisioning a huge side berm that keeps encroaching on the road every snowfall.
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #3
I use the FEL, and the front snowblower. Each has it's good and bad as you described. I need both for my property.
A plow would do me little good here.
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #4
I use a rear blade while driving forward. Will curl off the snow real well up to about 8". More than that and you have to back into it and push it off at a 45 degree angle.
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #5
I also use the rear blade angled while driving forward. This handles 75% of my plowing. I took someone's advice and added a strip of stall mat to give my blade a 3" rubber edge so as not to tear up my gravel drive. Thanks to whoever had that idea...it works great! It's more like squeegee the drive now.
For deep snow, I tilt the bucket down and lower it so it knocks down all but about 8".
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #6
I run a 6.5' front plow and a 60" rear blower. Driveway is 1,900' @ 10% hill. First pass I angle plow to the left and drive to the road, and then back up with blower & I'm done.
In the open areas, I plow all the snow to one pile and then blow it all into the woods. I had a snow pusher and still have my rear blade. For me, this is the best set up I have found it terms of time and not having to deal with snow banks or mountain piles.
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #7
Funwithahoe.
You forgot FEL mounted snow-plow....a lot more lift,easier removal with QA.
Also users should list size and weight of their tractors,what works on a large tractor may not work on the smaller rigs.
I use a 8ft.FEL mounted and a 7ft.rear blade,my total weight is about 6500lbs.
Also total average snow-fall plays a big part.
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #8
With the 2 tractors I owned I used loader, back blade ,then I converted a 61/2' power angle blade to my loader arms. I use the tilt for my right, left direction. I mounted the whole pusher and A frame to a bracket on arms. I ued this for 9 years with no problems. This last storm I measured the height of piles, 8+ feet. I don't use shoes once the ground freezes it does move some gravel when not frozen. I am using a 2615 Mahindra now. I tried to post some pix of this but for some reason I can't do it, sorry. :thumbsup: :thumbsup:
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #9
thanks for your replies....they help my thinking processes a great deal:)
   / Advantages/Disadvantages of Snow Plow/Blower/Scraper Blade #10
I use multiple methods. I have a 6ft grader blade for the rear of my 855. I always pull it rather than pull. It works reasonably well though I really need chains as it causes me to slide more regularly than I like. I have my loader to push snow with (have made a pass pushing and then clean up with blade). This winter I've gone back to my old stand by, a plow mounted on a 4wd ATV (it's only 23 years old :) ) now that I've rigged an electric lift. That little machine has worked quite well so far this year and I'm veyr happy with it.
I've though to find a front mounted blower since plowing does give limitations. I don't wnat to do all of my plowing in reverse so front mount is the only option. However doing so would mean the loss of my loader for however long I have the blower on. I use my loader over the entire winter so that's not really an option either.
So for now, I do as I have been. Maybe this year if funds allow I"ll pick up UTV with a larger plow and retire the ATV.
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A50854)
2016 WINNEBAGO...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
