Advice on what to do with my Oats Cover Crop
   / Advice on what to do with my Oats Cover Crop #1
Rightsaidfred
McCormick CX100 XtraShift
Im in Near North Ontario Canada, short season here for hay , winters are long and hard with lots of snow and very cold.
This past May I seeded about 8 acres with hay seed, and an oats cover crop. All growing well
I dont have access to a combine to harvest the oats this fall so im looking for what my options are, or what the best options are.
1) leave it and let it die off and get snowed down - hope it will allow the new hay to grow next spring and not choke it out
2) Bush hog it (cut high)and hope that the areas where the tires of the tractor run don't choke it too bad as it flattens the oats
3) Mow it with the disc Mower, rake it and Round bale it with the oats still on the stems and hope that I find someone to buy 20 or more 4 1/2 ' round bales of oat straw with oats attached. Im a bit afraid of this option as my mower is a Vermeer 9' 3 point hitch mounted disc mower, works well but for sure I have to rake too get my wind rows, Im a bit concerned about new hay/gras damage from raking so soon on freshly seeded field. I also dont want to be stuck with 20 bales of straw I wont use
I did option 2 last yr on a different field and it was "ok" but not ideal
Interested in your thoughts, thank you.
   / Advice on what to do with my Oats Cover Crop #2
It would be neat if someone would build a small pull behind combine again for small operations. I thought I heard of one but could not find anything. Maybe find a old one and restore it would be neat.
   / Advice on what to do with my Oats Cover Crop #3
If the oats were under my care I'd cut them in the early milk stage then rake & rd bale them. Waiting until after early milk stage to cut will get you formed hard seed heads which are rodent magnets. If you don't bale the oat crop then you should have a very nice, thick volunteer oat crop next season.
   / Advice on what to do with my Oats Cover Crop #4
In past times oats was cut early and used as green feed for cattle. That was with a Binder.
I should make good feed for horses also.
   / Advice on what to do with my Oats Cover Crop #5
I'd just leave it. Some will come back next year but just bale it right along with your new grass. It's not worth much as hay/straw they way it is right now.
   / Advice on what to do with my Oats Cover Crop #6
May I ask how from reading K5lwq's post that you can determine that his oats are not worth much as hay/straw? Almost any bale of fodder is better than a snowflake in the Wintertime.
   / Advice on what to do with my Oats Cover Crop #7
Well it's all relative I guess but as you mentioned as hay there's way more value when it's cut early. Very little feed value in straw. I guess I'm not familiar with the climate up there where he is at but I would assume it's past that point now. The OP indicated that the oats were planted as a cover crop. I would just let them be just that and return whatever nutrients they have taken up back to the soil for the what it is he really wants to grow, grass for hay. Just my opinion of course.
   / Advice on what to do with my Oats Cover Crop #8
I'll quote 1 of K5lwq's statements[/quote) leave it and let it die off and get snowed down - hope it will allow the new hay to grow next spring and not choke it out[/quote]
As I previously stated I think if oats are allowed to go to seed especially down here where I live one should have a ""very good crop of volunteer oats"" next year. I don't know if it would be thick enough to choke out his hay crop he planted.
[/QUOTE]
The oats dont re-grow here if they're left to go to seed and left on the ground. Not sure why that is, but they just dont. so we dont get the "volunteer oat crop"
So is the consensus to just leave them to get snowed down or brush-hog 'em down ?
   / Advice on what to do with my Oats Cover Crop #10
I suppose that's the reason different area's of the world experience different farming practices.
AGT MH13RX (A46443)
AGT MH13RX (A46443)
2018 Chevrolet Tahoe SUV (A45336)
2018 Chevrolet...
1901 LOG TRAILER (A43005)
1901 LOG TRAILER...
2013 WABASH 130BBL VACUUM TRAILER (A47001)
2013 WABASH 130BBL...
Utility Trailer (A45336)
Utility Trailer...
2025 Wolverine PT-16-01C 3-Point Quick Hitch (A47484)
2025 Wolverine...
