Buying Advice Advise Needed
   / Advise Needed #1
hodgepodge
I am considering purchasing a small tractor. I would like to purchase the smallest and cheapest tractor that could be equiped with an underbelly mower, fel, and backhoe. We own 2 acres and would use the tractor to mow lawn, dig trenches and move dirt. I live in Southern Michigan near Ann Arbor. I have been looking at the jimna tractors but most of the web sites claim to have the best jimna tractors and that I should be careful because some of the dealers tractors are not as good. I also would want turf tires. Where would be the best place to purchase the tractor. I am a decent mechanic and would be able to assemble a crate tractor. I used to own a Massey Ferguson to 35, which broke often, so I have worked on tractors before.
   / Advise Needed #2
Can't really give advise but I am very happy with a Jinma 284 with Jinam FEL & BH. My dealer www.4jinma.com, Shelden Tractor in Tn, did a good job with mine and I think the price was fair. I am sure any of the more local Jinma guys I see posting here will treat you right.
It is capable and although I have not used it much I am very satisfied with the quality of the machine.
Charlie
   / Advise Needed #3
O belive there are a few dealers near you..
check Johns's site for a list, I thin kTOMMY and ADAMS tractors are near you?>
anyhow they are good tractor byt may be more than 2 acres needs a 20 hp unit is plenty for sure as grass cutting is it's primary use then I would thing a MOWER which is tractor 2nd these are tractors 1st and mowers about 4th...
Mark M
   / Advise Needed #4
Sounds like Mark is having some fun on the 4th ! /forums/images/graemlins/grin.gif
   / Advise Needed #5
<font color="blue"> I would like to purchase the smallest and cheapest tractor that could be equiped with an underbelly mower, fel, and backhoe. We own 2 acres and would use the tractor to mow lawn, dig trenches and move dirt. </font>
Hey hodgepodge,
Probably a 224 or a 254 should be sufficient for work on your size place, IMHO. I would also suggest that you get 4wd. Jinma does offer a belly mower, but I'm not sure if it will mount on a 4wd. I'm sure others here will know about that though. Be sure to get PS, if you go 2wd, but I myself would not suggest getting a 2wd, as the 4wd, just has so much more traction ability ove te 2wd. If you don't have too many obstacles to go around, then a 3PH finishing mower, should be fine.
I myself have a 224, which is a 20 hp, and some say that it is a 22hp. /forums/images/graemlins/smile.gif It is doing a good job for me on my 7acre place, although, I haven't hooked up a 3pH mower to it yet. But evntually I will be doing that also.
It seems to me, that you are trying to do about the same thing that I am doing, and that is to purchase a tractor to do all of the maintenance chores at your place, and that is what I als intend to do with mine.
Keep in mind though, that a belly mower or a finishing mower, will be about 1K, and you could also have an inexpensive riding mower for that amount also to do your grass cutting. So you do have a couple of options to choose from for your grass cutting. I myself, still have an older MTD ridig mower that I can use, untill, I get a 3PH mower for the Jinma 224.
Be sure to get the OEM spring seat for your Jinma. If I were going to get the backhoe, and if th swivel seat does not have the spring suspension, then I would get both seats and just put the swivel seat on when I was going to be using the backhoe.
Get Your Tractors running &
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / Advise Needed #6
The Jinma belly mower runs off the rear pto, not a mid-pto like most belly mowers. The Jinma does not have a mid-pto. Get a 3pt rear finish mower, instead of the Jinma belly mower. Many recommend the rear discharge over side discharge.
   / Advise Needed
Thank you for the help. I need the tractor to put in a drain field, fill in a very large hole (used to be a deep swimming pool, about 30' round and 6' deep) by digging a pond in the back. I also have a stream at the rear of the property which i would like to deepen. You are right, it would make more sense to continue cutting the grass with a mower. Which Jimna model is the smallest I can put a backhoe on?
   / Advise Needed #9
I have seen backhoes installed on as small as 184. The Koyker backhoe is a little ligher and much smoother operating.
PM me if you would like a quote on a "demo" 184 I will tell you the story and offer you a great price with Koyker 140 loader. we can order a backhoe for it, only problem is I am in Arkansas. Wouldn't mind visiting Michigan, from South Lyon myself, let me know if you have an interest.
   / Advise Needed #10
I have to agree with buying a 4WD model. I have the 284 with turf tires and the 4WD has been a life saver on numerous occasions. While the turf tires grip well, it's amazing how often I can get the tires to spin on both dry and wet ground. I reach down, pop it in 4wd and I'm unstuck.
Be careful when moving dirt with the FEL. Don't use 4WD while pushing into a dirt pile and lifting or you'll break the front differential.
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2013 New Holland BR7060 (A50123)
2013 New Holland...
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
