MarkF48
Buy a can of spray paint, use a small amount it for a project, invert and blow nozzle clear, and then put it on the shelf. Go to use it 6 months later and the nozzle plugs up and nothing seems to work to get it working again consistently. Sometimes it'll sputter a bit paint and then just quit. Occasionally a nozzle from another can might work. Putting the can in hot water sometimes helps boost the pressure and maybe thin the paint. Soak nozzle in lacquer thinner and blow out with high pressure sometimes helps.
Two small projects today got kinda frustrating with two different cans that I only used last fall
Any tips or tricks you've used to resuscitate a spray can?
