After market Hoe performance Grand L30s and 40s
   / After market Hoe performance Grand L30s and 40s #1
tractorlogger
Landini 7860
I noticed on the Bradco site they recommended a hydraulic flow rate of 11 to 13 GPM for their 611 hoe...
The L 30 series tractors have an implement flow rate of less than 10 GPM
(9.8) max. I am not sure of the 40 series, but if it is no greater than the 30 series, would this cause problems meeting the specs given for the 611 hoe?
This seemed to me to be the greatest advantage of the L39/L48 Kubotas , the hydralics were up around 25 gpm, so much more than all the AG machines with the add on hoes?
Could someone straighten me out on this ..
   / After market Hoe performance Grand L30s and 40s #2
You might be hard pressed to find the difference in the two systems for just one gallon or even two. Now to go to the Larger L-39 and L-48 that is a good difference. It's hard to make desicions in this area and I often find that I rate things on a prioity list as to how to spec the tools and tractors as to what they might be best at and most needed. I feel hoe's need a subframe and I know bradco has a great hoe but for many jobs I don't like the reduced ground clearence.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
Genie GTH-644 (A50490)
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
