After market string trimmer head options that actually work
   / After market string trimmer head options that actually work #1
nickel plate
Veteran Member
CA
2002 New Holland TC40S
I am so tired of switching out various mega footage string trimmer spool heads and still winding up with tightly raveled "bird's nests". I have followed the directions time and time again-still wound and bound up!
I see that there are several aftermarket spool manufactures out there that offer spools that fit almost any straight shaft weeder that you only load two to four sets of 8"+- (buy pre-cut from them or cut your own from standard string stock) string per application and once destroyed, re-load in a minute or so and have at it again. Please offer up what works for you, brands and model numbers.
   / After market string trimmer head options that actually work #2
My wife has an electric Stihl string trimmer and I love the head on it.. you insert the ends of the string into the head and then turn the knob on the bottom to wind the string up.. Since you only put on about 10'/side you dont get the birds nest..
Stihl sells the head separately, and the model number varies with engine size but they call it 'Autocut C easy spool'..
Shakespeare make a similar head, call the 'easy wind bump and go'..
My Stihl FS90 came with the head you have to take apart and restring - BUT the dealer told me that if you only put on about 6' to 8' of string per side, you wont get the tangle issues.. I havent used it enough to see if that is true or not though
Brian
   / After market string trimmer head options that actually work #3
Look at the Oregon / Shindaiwa "Speed Feed" head.
I have one, and will never buy another brand. They are easy to string, not too expensive and tough. They also have replaceable wear parts so you can fix it instead of replacing.
[ame=http://www.youtube.com/watch?v=DA2qoeToSL8]Shindaiwa Speed-Feed Head - YouTube[/ame]
Brian
Thanks for the reply Brian,
I'm looking for the best string trimmer head that you thread in a couple of cut to 8" strings and hit the weeds for awhile until the strings are worn down and then reload and have at it again....
come on guys-the weeds are GROWING!
   / After market string trimmer head options that actually work #5
I got a Grass Gator Load and Cut. You can buy pre-cut strings, but I bought a big roll of string that's the right diameter and it works just as well as the precut stuff. It's much better to work with than any of the bump-heads I've used.
   / After market string trimmer head options that actually work #6
That's got to be the easiest to load head i've ever seen.
   / After market string trimmer head options that actually work #7
I second that
   / After market string trimmer head options that actually work #8
Brian
Stopping to open up the head, blow debris out with the air compressor, and re-string my 7 year old Stihl FS55RC is a bit of a nuisance. I had to do it again this past week. But I put two strings of about 14' each in it when I do it.
I decided a long time ago that I want one of those Autocut C Easy Spool heads and I'm going to buy one as soon as this old original head wears out or breaks, but after 7 years, it's not showing signs of giving up yet.:laughing:
   / After market string trimmer head options that actually work #9
My Stihl head is 21 years old and not worn out. The previous owners got a new trimmer as theirs was worn out. I have been using that worn out one for 10 years now. Maybe a dozen hours a year but a few string reloads a year. I have 4 thousand feet of low to the ground wire fencing which really eats up the string. I just bump the head to feed new string and move on. One reload usually does all the weed wacking I want to do for the day. I have never had string get wadded up in the Stihl heads. I usually use Stihl string but I have used other generic string bought at TSC, HD or other stores.
That fast loader is pretty cool though.
I see one that looks interesting on the Northern Tool site. Made by Better Heads LLC (fitting company name) it's called a Pivotrim 5101PT-C. I believe that it is a newer hybrid version of the older yet still available model "as seen on t.v."
The principle is exactly the same as my Bush Hog 480 Squealer rotary mower in that the two single pinned blades swing freely on the stump jumper plate so if I were to hit something immovable, the blade(s) not being ridgid mounted would fend off the object without sustaining catastrophic damage-in theory:eek:
This Pivotrim trimmer head has four rotating pins each with two string holes that you thread with a 16" piece of .095" common string through and loop back creating one double 8" station X 4=16 strings or just use two station pins for 4 strings.
Has anyone used one of the several models available?
   / After market string trimmer head options that actually work #13
Yup. And it works just as easy in person.
Truly an excellent head. The pros on Lawnsite all swear by it and I now know why.
Another great thing is its available as a Universal kit. The threaded part is separate from the head itself, so you can get threaded inserts from Oregon/Shindi to fit ANYTHING out there. It comes with the most common threaded inserts included.
   / After market string trimmer head options that actually work #14
To totally hijack the thread away from the OP's questions.. I did more research on the Speed Feed and it is highly recommended all over the interent..
My research on the Oregon/Shin Speed Feed head lead me to believe that..
a) the Oregon 450, the Shin 450, and the Echo High Capacity Universal Speed Feed (#78890-21001) are the same heads...
is this true? Either the regular capacity or the high capacity is available at Home Depot..
I found a post on another forum that said that to use the Speed Feed on a Stihl trimmer you need to buy (or make) some sort of plastic spacer so it doesnt rattle.. Can anyone clarify that?
Brian
   / After market string trimmer head options that actually work #15
I found that Walmart has a couple (Weed Warrior brand I think) and Home Depot has several different ones. And of course Stihl has their own version. What I don't know is whether one is better than another. I don't think I'd want the cheaper Weed Warrior heads from Walmart, but whether the Oregon/Shin/Echo are any better than Stihl's own leaves some doubt.
   / After market string trimmer head options that actually work #16
Brian
I believe that echo and shindaiwa are now one and the same, so im ASSUMING that the heads are as well. It certainly looks the same.
On a lighter duty trimmer, id get the smaller head. It will help the trimmer to spool up faster (less weight to accelerate)
As to fitting a stihl, Im unsure. All I use are Hondas and Huskys. I think i know what they may be talking about however. Is there a washer on yout threaded bolt that the head threads onto? The speedfeed head has a large, round "grip" above the head itself that is used to wind the string in. If this doesnt fit up tight to the flange (washer) of the threaded bolt, it could rattle.
It should be an easy fix if it rattles, just drill out some plastic to fit the bolt and wedge between the "grip" and the mounting flange.
Be sure any kit you buy has the correct thread adapter for your Stihl. It needs to be the correct pitch and direction. Some trimmers use LH thread
I took my John Deere S1400 over to two very well known mower/landscape supply shops in my area-these shops also have other shops out of my area and in both cases they couldn't unthread part 29 from part 30 to even establish if a Shindawa or Echo "speed feed" bump head would fit. These guys were nealing on the shop floor straining and grunting away but couldn't get part 29 off. Prior to this I searched everywhere for my operator's manual-found every other manual (even one for a HF bottle jack) but not the JD manual so I didn't know if part 29 was threaded L or R or just pressed on.
I went on the JD site and they want money:mad: for an operator's manual download which I would have eventually done if it weren't for the fact that most other equipment manufactures will give you their download manuals for free:). What's with JD??? The folks at Pivotrim were gracious enough to send me this attached schematic. So I got home, put the straight shaft gingerly in the vise, put a Rigid pipe wrench on part 30 and a box end on part 29 and turned the box end clockwise and off it came. Simple dimple.
I ordered the Pivotrim 5101PT-C from Northern Tool and a "Trimmer Assist" tether type harness that incorporates a padded shoulder strap and set of bungee cords to the trimmer from another dealer. I'll update the performance of these two products in a few weeks.
  • John Deere S1400.pdf
   / After market string trimmer head options that actually work #18
From what I thought I understood on another forum was that the 'universal head' requires a different 'nut' to go in the 'equivalent part 25'/head that would then fit #29
http://www.lawnsite.com/showthread.php?t=351422&page=2
What i am not sure is if the nut comes out of the old stihl head OR comes with the Speed Feed head..
Brian
   / After market string trimmer head options that actually work #19
Brian
In the box with the speed feed head, there are several "nuts". Actually they arent really nuts, but are the same hex on the outside with various threads on the inside. I wouldnt cut up my Stihl head to get at the nut, it might not fit.
On the shindi/oregon head, on the inside, there is a hex bore. You put whichever "nut" matches the thread on your trimmer in there. Then you assemble the rest of the trimmer head.
If the proper nut isnt included (probably 90% of the trimmers are included in the box), you can order it separately from Oregon.
Heres the link to the Oregon catalog:
http://www.oregonchain.com/pro/2012Catalog.htm
Go to page 761 for the schematic. Page 762-763 for the adaptors. I dont know what model you have, but you should be able to find it there.
   / After market string trimmer head options that actually work #20
I have one and I love it...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
2017 KOMATSU...
