Aftermarket Bearings
   / Aftermarket Bearings #1
Dale1995
Caribou,Maine
John Deere 2320
I have a 2320 John Deere with a front mount 54" blower, this spring I want to replace the bearings on the quick attach front pto, these are bearing designed for a hex shaft, plus I also want to replace some of the other bearings instead of waiting for something to go bad and it is 25- in the dead of winter. The bearing from my local JD dealer cost 25$ each, but I am finding that I can go online and buy them for about 8$ each..... why the difference in price? Is the JD Bearing better quality or am I paying for the name. I want to put as good a bearing as I can. Have any of you out there had any experience with this. I am wondering which way I should jump. I would appreciate any comments you have on this topic!:thumbsup:
   / Aftermarket Bearings #2
I replaced a bearing in my friends Mott flail mower five years ago with a generic bearing. the cost savings was about 40%. So far no problems, though I should mention it was not a Chinese made bearing that we used.
   / Aftermarket Bearings #3
I helped a friend replace the auger - side bearings - on his snow blower. He used Timken brand and that was eleven years ago. Still works fine.
   / Aftermarket Bearings #4
Timken is top of the line. I bet that's what OEM used in the first place. A lot of the time these OEM's go to great lengths to set their stuff up with bearings that you can't cross reference without paying as much as you will from THEM. You can't get most of those "shall we say odd" sizes at the discount places and the last time I forced myself to go to Kayman Bearing they were cheaper but I had to order a lot of at least 5 and shipping and tax. I'll never go near that place again. I replaced those side bearings on my Ariens 8hp blower last year and paid 20 apiece. You can never go wrong with timken though no matter where you get it and Cheaper is better.
   / Aftermarket Bearings #5
Very few bearings can not be replaced with aftermarket ones, just bring the old ones and let the bearing shop measure.
You often will be offered choices, USA made or import.
On a snow blower I'd go for import as in the order of things a blower is not a precise high tech device, also access is fairly easy.
A good shop also can supply U-joint X's in most cases, again on a PTO shaft (mere 500RPM) I'd be satisfied with import quality but I'd insist on greesable X's.
   / Aftermarket Bearings #6
All bearings are aftermarket. Not a single tractor or equipment manufacturer makes their own bearings. Choose bearings based on your comfort matrix of price, convenience, and quality.
   / Aftermarket Bearings #7
I think that is a bit exaggerated. Yes, there are times when an OEM uses a special hard to find bearing. But I doubt the reason is to make replacing difficult. Probably 99% of the bearings that OEM uses are standard inch or metric series bearings. MFG and quality of their choice. Timken, SKF, NTN, koyo, NSK, RBC among other are all good brands.
+1
   / Aftermarket Bearings #8
You can't tell a bearing from its appearance. There are different seal types, different separators, different grease. Are they relube or fully sealed? Blower bearing sounds pretty straight forward and I would expect easy to replace so the risk is low. However, does the John Deere bearing use a special low temp grease knowing it is a winter application. How about the seal? Does the John Deere original have a low temperature seal? There is always some risk, but the less expensive bearing you install my be better than the John Deere you buy.
The last time I was involved in a bearing evaluation by Timken - they had a test stand with 16 bearings all running under the same load in the same test cell, completely identical test conditions. Bearings were all instrumented to monitor vibration, temperature, and possibly other parameters. Failure was when 1 of the 16 bearings began to vibrate indicating pitting on a bearing race or temperature climbing above the rest. This was used in establishing bearing life but remember only 1 of 16 bearings was beginning to fail. How long would the others have run? Every few years Timken would increase the load capacity of bearing groups due to improved steel production capabilities. Except for application failures due to a company using the wrong bearing for an application or end user operating a machine outside its intended range (including storage where condensation can get into a bearing causing corrosion which will result in rapid failure), steel used in making the bearings is the most important factor in bearing life. If I limited bearings to only those not built in China - not sure how that's done. Every major bearing manufacturer builds some of their bearings in China.
   / Aftermarket Bearings #9
A whole lot depends on the application.
On a helicopter rotor bearing or wind generator Timken or OEM for sure.
On a snow blower PTO shaft or auger that turns 540 or 71 RPM (and relatively easy access) what's the diff.
Do you really think that the manufacturer of that blower buys premium Timken?--don't think so, lowest bidder.
   / Aftermarket Bearings #10
If there is any question on getting the correct bearing, go JD - not worth the money to get the wrong thing then have to get it again. If you are sure about the size, get the bearing on-line. I'd put money that the JD bearings are the same made-in-China crap that you can get for $8 on-line. Your other option is to try to find a quality bearing from the Eastern bloc, Italy, or Japan, but you'll pay at least the same $25 for those. Personally, I'd go online bearings and if you need two, I'd buy 4. They'll probably last the rest of your life, but if they don't, you'll already have a set to put in and you're STILL ahead $18.
Almost forgot - just about all of the implements such as snowblowers and power transfer hitches use standard AG bearings - self-centering with extended locking collars (cam and/or allen). They're all pretty much the same.
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2020 Chevrolet Silverado 3500 HD 4X4 Service Truck (A52377)
2020 Chevrolet...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
FAKE (A52472)
FAKE (A52472)
