aftermarket power steering MF 135
   / aftermarket power steering MF 135 #1
myrondf
The pump is sending fluid to cylinder, fluid is going out cylinder to reservoir and blowing out the vent hole of the reservior. What is wrong?
   / aftermarket power steering MF 135 #2
Your details are too vague give you much of an answer but here's what came to mind.
If you have water in the fluid it could be causing the fluid to foam up and displace the air in the system until it was pushing out the breather. This could also happen by using the wrong fluid.
It's too full.
I would suggest re-asking your question but include some details pertaining to the conditions that make it overflow.
FORD 3610 TRACTOR (A51247)
FORD 3610 TRACTOR...
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A51247)
1996 UTILITY 101"...
200722 (A51247)
200722 (A51247)
UNUSED FUTURE 24" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 24"...
Case IH 75C Farmall (A50123)
Case IH 75C...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
