Aftermarket seat for Ford NH 1920?
   / Aftermarket seat for Ford NH 1920? #1
AlbionWood
Albion, CA
Ford NH 1920
Have plumb wore out the original seat on my Ford NH 1920 and as I have a birthday coming up, wife says I can get a fancy new one. Problem is, I can't figure out which if any of the aftermarket seats will fit the bolt pattern. I took the seat assembly off and measured, 6+1/16" x 9+1/4" center-to-center. Most of the bolt patterns I'm finding are much narrower.
Am I doing it wrong again? Is there a drop-in aftermarket upgrade, or will I need to do some drilling?
   / Aftermarket seat for Ford NH 1920? #2
Other than going with a factory replacement with the same bolt pattern you'll probably have to do some fab work to get it to fit. I replaced a non suspension (just slid Fwd and Bkwd) with a universal spring suspension seat from TSC for about a hundred. I did have to set the new seat on the sliding frame, mark the holes and drilled. Then I removed the slide frame, took it apart and welded bolts up from underneath. re-assembled the slide frame, bolted back on the tractor and bolted the new seat on. Other than the seat it was just some time involved but not hard to do.
   / Aftermarket seat for Ford NH 1920? #4
The part number for the seat is E2NNA405AA99M, they are available in the aftermarket in black and blue.
   / Aftermarket seat for Ford NH 1920? #5
I know this is a late post but we also went to TSC and bought a new seat with frame for about $100 and just drilled new holes to mount the new seat, much cheaper and very comfortable.
UNUSED CFG INDUSTRIAL SSECAG-Y HYD AUGER (A51248)
UNUSED CFG...
JLG 36AM-DC VERTICAL ELECTRIC PUSH AROUND MANLIFT (A51247)
JLG 36AM-DC...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
CHALLENGER MT525B TRACTOR (A51247)
CHALLENGER MT525B...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
