Agratec auto stacker
   / Agratec auto stacker #1
Hello all. Anyone have any experience with one of these auto stackers. I can have the one in this photo for free once the snow melts here. Is it worth the trouble. Is it even a complete unit. It's hard to find info on it. Any info or advice would help alot. Thanks
   / Agratec auto stacker #2
Is this for square hay bales? Does not seem to have a bale catcher in front and too little to stack it.
   / Agratec auto stacker #4
Ah that is what I would call a bale barging or bunching machine.
We used to have wood bardges. Just a number of 2x10's to get about 4 or 5 feet wide bolted to a single board on the front edge. A poor ape stood on the barge catching each bale and stacked it on the barge. When the little stack was done he took a pole/pipe and rammed it into the ground ahead of the stack and forced it off the barge. Rinse and repeat all day long and don't get you foot caught between the planks.
I love hay making machinery. So of it is very Rube Goldberg.
   / Agratec auto stacker #5
Those were used lots when I was growing up in Montana. A hay fork (same forks were used to pickup loose unbaled hay) on a Farmhand F10 was very tipically used to pick up the stooks you could get 4 stooks on at time vs 10 or maybe 12 bales.
   / Agratec auto stacker #6
i only spent one summer with one of these but they were such a help. the summer of '76 we had to cut hay elsewhere and haul it because of the drought and we worked with a couple of neighbors who had square balers and these stookers and we cut and loaded about 2500 acres of hay onto flatbed semis for hauling 200+ miles.
What this machine does is stack the bales at an angle automatically as they get pushed out of the baler. It stacks three on the bottom, then 2 and then one on top making a nice triangle. The key to how they work is that only a corner of the bale is sitting on the ground allowing air to get at all sides so you can bale a little tough and it will dry. they also shed some rain which a bale lying on the ground does not. They also are so easy to pick up with a loader and put on a trailer or truck or whatever - six at a time.
Yours looks to be in pretty good condition. Although I cannot see the details in the photo all the main parts appear to be there. For me the neat thing was the simplicity - fully automatic with no moving parts. There is a market for these thing sin various parts of the country, the problem is that many people do not even know they exist or what they will do for them. If you are going to handle square bales without a full blown stacker, this is the way to do it. You do not have those very dangerous haywagons, you can do the job with a lot less people, and if it takes you a few days to get your bales inside you will not lose them.
Stump Bucket (A50322)
1991 Peterbilt 378 T/A Dump Truck (A50323)
1991 Peterbilt 378...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
2' Auger Extension (A50774)
2' Auger Extension...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
1985 Chevy C8500 Auger/Derrick Truck (A50323)
1985 Chevy C8500...
