Tiller Agric Tiller Problem
   / Agric Tiller Problem #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
I have an Agric AL50. The bolts holding the gearbox to the tiller keep either backing out or shearing off. I drilled and tapped the 2 holes in the gearbox to a size larger bolt, installed larger hardened bolts and a plate to prevent the bolts from backing out. Well, they don't back out - they now shear off. Have any of you had this happen and what did you do to remendy it?
I am considering installing a U bolt around the shaft carrier pipe and secure it to the top of the tiller housing between the gear box and the top chain sproket.
   / Agric Tiller Problem #2
I have the 45" gear driven model, it is only a year old and no shearing of the bolts on mine....atleast not yet.
Have you tried grade 8 bolts?
Yes. The larger new bolts I installed are grade 8. The only support for the gear box and drive carrier to the top chain sproket is the 2 bolts. Most other tiller manufacturers have other supports between the gear box and chain housing or support pipe to the other side of the tiller. That's why I thought the additional U bolt support would help.
wushaw said:
Ok are you talking about the two bolts holding the top/angled gearbox in place there on the R/H side of the gearbox?
http://www.tractorbynet.com/forums/...lf/76824d1179120240-tiller-stand-dsc00352.jpg
Yes. The 2 bolts (that you can't see in the picture) on the RH side of the gear box in your picture. The bolts go through a piece of angle iron welded to the top of the tiller housing in to threads in the tiller gear box.
Bolts marked #11 in attached picture.
viewPrd.asp
   / Agric Tiller Problem #6
Well that is interesting. The only thing I can think of is something is causing alot of torque to sheer them bolts off.
Does everything else operate smooth, nothing binding up or anything like that.
If all else fails then you could add another bracket to pick up the bolts on the back side to assist in holding the gearbox in place.
The tiller vibrates a lot when working and that shaft has a lot of torque in it. Those 2 bolts take the brunt of the vibration and torque. I figure the combination of vibration and torque back-out or shear the 2 bolts. That's why I thought a U bolt between the right-angle tiller gear box and the chain cover would help.
   / Agric Tiller Problem #8
U bolt with a spacer would help.
   / Agric Tiller Problem #9
something si wrong
it shouldn't vibrate like that
and those bolts shouldn't shear
I probably have a 100 acres or more of tilling on my 5' agric over the last couple years and those bolts are still fine.
you're fixing the sympton, not the problem. something is torqued down below.
LoneCowboy said:
something si wrong
Thanks for the responses. Any ideas what could be causing the over torqueing problem?????? The tines rotate freely by hand when the PTO is not attached to the tractor. The only thing I can think of is very hard clay undercoating the bottom of the tiller housing causing very little if any clearance for the tines. This happens after tilling for a while in some of my more loamy fields. the bolts have backed out or sheared off at least a dozen times.
By the way, I don't have a clutch or shear bolt on the PTO drive to the tiller. Could this be part of my problem? I know I should have one but I wouldn't think it would solve this problem.
If anyone has anymore ideas I would appreciate the help. Thanks.
2009 Lexus RX350 (A50324)
2009 Lexus RX350...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
2014 Doosan DA30 (A52128)
2014 Doosan DA30...
