Air brake problem
   / Air brake problem #1
madimoo
7830 JD
I have a Freightliner that the air dump on the bottom of the air dryer does not close properly after it vents air. If I push and hold the valve in it catches and holds the air but it is a problem if it occurs when driving as my air pressure drops. Does anyone know where the electrical signal comes from that is supposed to activate the dump valve and hold it.
   / Air brake problem #2
There is no electrical signal, the airing is for the heater to keep all that water from freezing in COLD weather.
I'm going to guess you have a Bendix "AD-9" air drier, at least I hope so.
There should be a LARGE brass looking nut on the BOTTOM of the drier with a fitting comming out of it (discharge hose). After you drain the air tanks completely, carefully remove the hose and fitting from the brass nut looking thing. Then remove the nut, there is no air pressure now so nothing to worry about. Clean the whole assembly (nut and contents) with ether or brak-cleen and re-install everything. The air system should now work normally again.
   / Air brake problem #3
If cleaning doesn't work, you may need to replace those parts...usually it is dirt but they can wear out too!
2006 International 9400i (A52748)
2006 International...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
Unused Delta Crash...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
