Air in hydraulics 3720
   / Air in hydraulics 3720 #1
KennedyDiesel
Veteran Member
Central WI
I have been experiencing air in my hydraulics for some time now. Pretty much since new. It is especially noticeable when I use the hydro hard (like plowing) and then lift with the loader. I hear the air go through the pump and "chug" slightly as it raises. It's not nasty, but it's there and it isn't right. Has anybody else experienced this?
Just a follow up on this. I had the machine to the dealer and I couldn't make it do it, but they did look into it and submit a case to DTAC. This a known issue on some machines, but it deosn't sound too common. It's noted in the Deere systemto be tied to using the hydro under heavy load (pushing snow and dirt) in A or B ranges (pushing in C would be "pushing it") followed by loader use. They have issues a warranty extension for this particular system/issues related to this.
   / Air in hydraulics 3720 #3
I have the same condition on my 3720 but my dealer thought it was just the pressure relief bypassing. Do you have the DTAC#?
   / Air in hydraulics 3720 #4
OK.... what's a DTAC? Is that something that Deere will take care of even if your warranty has expired?
AKfish
   / Air in hydraulics 3720 #5
"DTAC" is the John Deere Dealer Technical Assistance Center... This is where us dealers go when we cannot find the fix for a problem - it is a central hub that connects the dealers with the factories and the Deere service guys. If an issue becomes a trend, or even if there are only a few instances of it, it helps Deere and the dealers stay on top of what is going on out in the field.
In KennedyDiesel's instance, since they have yet to determine the actual problem (and consequently a "fix" for it) they have issued an extension of warranty, in regards to this problem only. That way if your tractor goes out of warranty while the issue is being addressed, it will still be eligible to be repaired at no cost to the customer.
2016 Chevrolet Traverse 1LT SUV (A50324)
2016 Chevrolet...
Massey Fergusson 4253 (A50120)
Massey Fergusson...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A50323)
2019 International...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2013 Cadillac Escalade Luxury SUV (A50324)
2013 Cadillac...
