Air in the water coming out of faucets
   / Air in the water coming out of faucets #1
janddetc
Cedar, Mi
case 350D dozer
I have air coming out of the faucets in my house. it worked great until I had furnace trouble I have a GEO furnace (heat pump). before the furnace issue I had good water pressure throught the house and enough at the heat pump. The dole valve was shot, and after it was replaced, and the furnace working, I had low pressure with air when heat pump was working. when the heat pump shut off, i had great pressure in the house. Any ideas?
   / Air in the water coming out of faucets #2
Sounds like you have a hole in the geothermal piping. Does the heat pump have a valve that closes when the heat pump shuts down, I would think yes by your description of symptoms. HOW to find your leak is best guess but I would start with fitting close to where the repairs were made.
Thanks for the info. I will see what I can find
Thanks for the info
2023 Kubota KX71-3S Mini Excavator (A52377)
2023 Kubota...
2013 Kubota RTV-X900 4x4 Diesel Utility Cart (A53421)
2013 Kubota...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2019 HINO 195 LCF BOX TRUCK (A54607)
2019 HINO 195 LCF...
