scesnick
Veteran Member
I posted recently about finally getting my residential water from the creek instead of the crappy well we drilled.
I put a 3/4HP submersible pump in the creekbed with a check valve down there. then the waterline runs 500ft up to my house. I then have another check valve just before my 30/50 pressure switch.
The problem is everytime we turn the water on we get a large amount of air into the system. I am REALLY,REALLY hoping I don't have a hole in the supply line. I did dig it up once this summer to find the electrical splice. But, I didn't think I touched the pipe. (atleast i hope I didn't)
I do have the submersible pump laying on it's side under the water. It is inside a 6 inch piece of schedule 40 pipe with plenty of holes drilled into it. Could the pump be causing some type of vortex allowing air into the system? I stood there and watched while the pump ran and I didn't notice a thing.
Since I have a check valve right at the tank, The pressure in the tank wouldn't change even if the pipe was leaking underground. Atleast I wouldn't think so.
Possibly the tank is bad but it doesn't seem waterlogged.
What if I took the check valve off at the tank and then re connected the pipe. I would think if the pipe was leaking underground then, the pressure would drop and the pump would kick on even when the water is not running ...
maybe I am way off, Maybe it is in my tank or even the pressure switch ....... Any ideas. ????
