airportrep
   / airportrep #1
airportrep
Kittery, ME
Branson 3725H
I recently purchased and installed a new NorTrac log splitter valve on my old log splitter. The motor will not start connected to the pump and I suspect that I have air in the system and need to bleed it but I'm not sure how to go about it. I also changed the hydraulic oil and filter when changing out the valve. I appreciate any instructions.
   / airportrep #2
   / airportrep
It's a nortrac wv-br01open center. I installed it per the diagram enclosed with the valve.
Thank you,
Joe
   / airportrep #4
If you do have any air in the hyd system, it will self bleed as you use the machine.
With the pump output hose in a bucket, does the pump pump fluid with engine running?
It is hard to go wrong with the pump flow with the valve lever in neutral. There is an open path for the fluid to move. Pump output to IN port of valve, valve OUT port to return filter and to tank. Lever dictates which the cyl will move.
   / airportrep
Thanks J.J. I'll let you know how I make out.
Joe
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
