Backhoe another backhoe question
   / another backhoe question #1
baldyfan
fargo,nd
olderjd for now
I am looking at a 3pt wallenstein model 600. First, it would go on a 50 hp tractor, is this to small of a hoe for the tracto. Also what do you need to do for hydralics on these 3pt hoes. The normal rear remotes wouldnt work would they?
I should add that the main purpose for this is just for posthole digging, a little trenching(not water), clean up work etc. It will be used in gravel country. I have tried hydro augers but it didnt work.
   / another backhoe question #3
I would still get a frame mount hoe and of the appropriate size is we are talking a modern tractor. Because a modern 50HP tractor isnt nearly as heavy or rugged as some older ones. Only way I'd consider a 3PH hoe is if it is a 1980's or older machine. And then just keep in mind that it is a 3ph unit when you get into some though digging that likes to move the tractor around.
Have you tried the hydraulic PHD that go on the FEL or a skidsteer where you can apply downpressure??
LD1, I tried the skidsteer type... not much success. I would be mounting it on my 401d Jd industrial. It a 84/85 model or around that vintage. A local dealer has been sitting on the 600 and wants to get rid of it fairly reasonable. I was thinking i would be more apt to shred the bh than the tractor. Thank you for the reply. I was just worrying about how to power it and hadnt really thought about the rest
   / another backhoe question #5
Not really sure on that model of BH, Some use tractor hydraulics, and some use a PTO pump. Your tractor should be fine with a BH like that though.
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2013 ISUZU NPR STAKE BODY TRUCK (A51219)
2013 ISUZU NPR...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
