Another MF 230 question
   / Another MF 230 question #1
zenmek
Kentucky (in the bluegrass!)
Kioti LK3054, IH cub cadet 782, Grasshopper 721D2
Does anybody know where the hydraulic filter for this tractor ( '78' MF 230) is?? Is it a spin on cartridge, or just a screen, or perhaps a hidden filter element. Any help would be great!!
   / Another MF 230 question #2
I changed the hydraulics on my 230 and I'm pretty sure it was a screen underneath a retangular cover under the transmission, I don't have that tractor anymore and I'm not 100% sure but take a peek there. Cheers
Thanks for the quick post! I will tell the owner, hopefully he will be able to find it /w3tcompact/icons/grin.gif
   / Another MF 230 question #4
There is a plate under the rear end housing (Triangular with 3 bolts). You will have to drain the oil from the drain plug on the lower side of the same housing. Once you remove the cover you will see a cap that it will unscrew by gripping the tab. Inside there will be a strainer. You will need to remove the nut for the strainer to come down out of the hole. That is your filter for the 3-point hydraulic system
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
Booster Cables (A59230)
Booster Cables...
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
