another question---4WD or hp?
   / another question---4WD or hp? #1
scrimshaw33
Bronze Member
JD 4520 w/ cab and FEL
Which is a better option to have 4WD or more hp?
Was weighing getting a New Holland TC33AD 4WD/hydrostatic versus a 45 to 80 hp 2WD New Holland each with front end loader...is a 4WD necessary or more important than having more hp? Not sure I can afford more hp and 4WD, atleast haven't find one yet, but a 4 WD with less hp or a 2 WD with more hp is in my price range.
   / another question---4WD or hp? #2
HP isn't much use if you can't get it to the ground, I wouldn't own a CUT that was 2wd. Many times I have been working the tractor and had the wheels slip, just reach down and slide the lever up to connect the front wheels and keep on going. Enough power is seldom an issue, applying the power can be.
The tractors you are talking about are larger than that and heavier so might work well enough in 2wd. It will depend somewhat on the uses you plan for the tractor and ground conditions in your area.
   / another question---4WD or hp? #3
I went through this same dilemma. I ended up going with 4WD because of the smaller form factor of the tractor. I intend to do a lot of woods work, so the maneuverability and size of the tractor came into play. 4WD also makes sense in those environments.
We'll need to know more about the intended uses for the tractor. If you're using the loader on a concrete barn floor, that's different than if you're hubs-deep in mud/manure/snow trying to use the loader, where 4WD would be helpful.
If this is primarily a pulling/field tractor, 4WD provides less benefits.
-rus-
   / another question---4WD or hp? #4
IMHO, if using the tractor for mostly traction applications, go with the highest horsepower/4wd combo you can afford. However, if you need PTO applications more than ground work, high HP is a better way to go. Also, if you are on steep or hilly ground, 4wd is better and safer.
   / another question---4WD or hp? #5
It all depends on what your going to do with it. Sometimes the hp is needed to run implemets. A guy up the way from me bought HP because he thought it would make his tractor tougher then mine. Well we both use our machines for close to the same stuff, quess what, he can have his HP especially when I'm passing him by with my 4 wheel drive. Personally I'd never go back to 2wheel for "what I do"{key words}
   / another question---4WD or hp? #6
100% Depends on the tractor. My little Kubota BX2230 needs 4wd or it will spin the turf tires too easily. My Dad's MF 245 is 2wd but never gets stuck or spins -- it weighs enough to hook-up and go.
On a bigger tractor they weigh enough that 2wd is fine for most. On the little CUT or subCUT tractors 4wd is required...
   / another question---4WD or hp? #7
depends on what you are doing... a big 2wd machine can pull big implements. a small 4wd machine can't pull those same implements. big machines and big implements have their own pro's and cons.
bigger machines get more traction by having larger tires with more ground contact, even dual rears, and flotation fronts that don't get burried but skid over wet areas while diffy loced dual rears plow you thru. gets you there.. might make a mess of a feedlot or pasture in monsoon season though..
In flat areas where bigger work can benefit you.. it may be beneficial to have a large 2wd vs a smaller 4wd.
I live in florida.. I was mowing with a nice compact 32hp NH 1920 4wd and 5' mower... took me forever to mow 13ac with it... I traded up to a ~95 hp machine/15' mower and droped mowing time by 2/3's.. cost me a lil.. but was SOOOOOOOOOOOOO worth it. I had only used that compact in 4wd 1-2 times.. both of them I got stuck anyway.. so that 4wd didn't help me any. ironically.. never had the large 2wd stuck.. and have taken it thru places that swallowed my gmc yukon up to the frame so bad it had to be DUG out...
you need to look at your tasks and decide frame size.
If I was doing big work.. i'd get the big tractor... etc.
If I was doing lots of loader / landscaping work.. the smaller 4wd might be better for many reasons.... IE.. I'm not going to mow next to my house with the batwing.. however one of my compacts with a loader I have no problem pulling alongsid ethe house without fear of say.. knocking down a wall!
soundguy
   / another question---4WD or hp? #8
That might have been my answer a few years ago, but my answer is different now. I prefer to get just the hp that I need and no more. Smaller hp tractors are more nimble that larger tractors, and to me nimbleness is most important if you are using the tractor for many tasks. If I were plowing thousands of acres of land, and time was a factor, I would tend to agree with you. This rule only applies to tractors, not my cars and motorcycles. :D
As to 4WD... I always have mine in 4WD. I suppose if I were just driving it down the road to go somewhere, I would switch to 2WD.
   / another question---4WD or hp? #10
I used to have a Kubota M4700 2WD (45 hp) that I added a FEL to. One of the dumbest purchasing decisions I ever made! The bucket was virtually useless and spent most of it's life in disconnected in the barn. Now maybe if you moved up to a big tractor with heavily loaded rear end, it would be okay for lighter duty work (e.g. scraping manure, etc.)
Also realize that on going down any steep hill, a light rear end means no brakes.
Last year I finally traded the M4700 for a 4wd M5040. Much, much better. Of course, I got hit on the trade in since there isn't much market for a 2wd tractor with a loader on it.
2023 DOOSAN DL220-7 LOADER (A52706)
2023 DOOSAN...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
