Any Camper Advice?
   / Any Camper Advice? #1
HCJtractor
Veteran Member
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I’m thinking about buying a used camper (19, or 20 ft) to place on my farm/hunting property. I’d like to spend an occasional night there in the fall and winter, but never when it’s hot. Hopefully talk my wife into joining me. But there’s no electricity, well, or septic system. It’s about 20 miles from my home, not too far out of town. My buddy is interested in sharing 1/2 the cost, but he would use it occasionally for taking trips in the nearby mountains, but never too far, within a couple of hundred miles. I have no problem sharing ownership, as we jointly own many farm implements, as well as ownership of the farm.
Not having any experience, are campers self contained enough to leave at the property, spend the occasional night there especially during hunting season, and not be too much trouble? I have a nice quiet Honda generator, and a 300 gallon cistern there.
Would solar help? How about dumping sewage and gray water? How often and where? It’s a 300 acre rural property if that matters.
Thought about building a rustic cabin, but without electricity or water, just don’t see that being wise, plus really don’t want to have to go through the building permit process. I’d like to keep it under 10 grand, but I see many fairly decent used ones in that range. Would this fly and if so, what should I look for?
   / Any Camper Advice? #2
I can give you my experience with my rv on my hunting property for 5 years.
Had electricity and septic and a shallow well. The well was always a pain. Would break or freeze but they're cheap enough to maintain.
Generator would be a good idea and easy to carry. Make sure it's sized right. Solar panel to keep your camper battery charged would be a good idea also. 10 watts is plenty.
You will need water. To get it into the camper you will need a way to carry it there and pump it in. Before I had the shallow well it was a huge pain. A 12v pump would help and a larger tank that you carry with you.
You need propane for heat and refrigeration. The fridges work when the power is off (with the 12v battery and propane) but you can turn that off but make sure to leave your fridge door open.
The more often you go the better. Like anything that's left unattended it will rot and wither of you don't maintain it.
I didn't have any issues at first but eventually got some mice and bugs, ants and the like. So you'll need repellent. I used sticky traps but they come with their own issues.
If you keep blankets, coveralls, shoes, clothing etc they can become nesting items for varmints.
The plumbing should be clear during freezing weather of possible. Just drain the lines.
Gray water is no problem but black water needs to be dumped properly or buried somewhere which means you'll have to tow somewhere which is a huge hassle because you'll be hooking, jacking, etc. Maybe dig your own dump station with a 55gal drum close by buried and cover it. Like a mini septic.
Eventually, someone found the RV and broke in. They then broke into my 40ft container so I moved the rv off the property. Just too hard to maintain but you're close so you can check on it often.
Camper roofs will bake in the sun. They aren't made to last long. The awnings also will dry rot so that's a replaceable item.
If you worry about vandals or thieves a game camera pointing at it may help.
It's nice to have that oasis on a hunt trip instead of having to bring everything in a truck each time. But a cabin would be more ideal but way more expensive.
A handy house might works, though. No permits needed. Furnish to. Your liking.
The less you keep in the camper the less you'll lose.
   / Any Camper Advice? #3
Great write up, Joe. Personally, I would have a hard time parking a camper that is properly equipped out in the boonies. I like decent quality stuff and I absolutely despise those who steal/vandalize and would want to do bodily harm if I caught them in the act. I think I would rather have an RV that I took to/from that was outfitted with the stuff I wanted and could keep close to home to restock/clean, etc. Just my two cents. I do understand the convenience of having a place to stay that you don't have to tow but the water/waste, power, etc. needs to be dealt with... good luck and keep us posted.
   / Any Camper Advice? #4
Do you self a favor and build a small rustic cabin,wire it to run off a generator.Haul your water.Neighbor went your route with travel trailer on his property and has regretted since.Mice,rot,leaking roof,general upkeep to name a few.
   / Any Camper Advice? #5
I just sold a 5th wheel that I used 2 times in 2 years. Used campers are a dime a dozen in my area.
I agree with you. It may be better to set up a nice gravel pad or parking spot and haul in and out if the OP believes a camper is the way to go. Joe did indeed cover it nicely. With the amount of stuff that has to be hauled in and out every time a parked camper is used, I think I'd drag the whole setup in and out. That way you can replenish water, propane, etc when you're home and also find a spot to dump the black water tank when you're out in civilization. Hauling in and out will also minimize or eliminate vandal and thief damage.
   / Any Camper Advice? #6
Eventually every camper roof leaks and the damage can be bad if left unattended for many days/months. Rodents will get into it and be a mess to clean up their fecal matter etc. Potable water will be a problem because you will have to pump it into the storage tank, then getting rid of the black water (human waste) has to be done at a disposal site so you need to hook it up to take it for dumping. Grey water (shower /sink) water could just be drained into the soil a few feet from the trailer, but even shower water will start to stink if a lot of it is dumped close to the trailer.
If your trips are short duration, perhaps solar power to recharge the batteries would work and they would last for a few days for running lights, so no generator would be needed. You could even boost the battery capacity by adding another battery or 2 to the camper. Most RVs have 2 each 12v batteries wired in parallel so as to provide 12 volt service. Adding another battery (or 2) would allow for longer service. You may need to up the solar charge rating to at least 50 watts so as to replenish your batteries while you are there. I would put a small solar panel(10-15Watt) on the roof for maintaining the batteries, take the 50 watt home each time. The batteries would also power the water pump to activate your shower/sink water so limiting your shower times would conserve power.
Freeze protection will be a pain in the winter and everything will need to be drained blown dry or RV antifreeze induced into the lines after each visit. Busted water lines in a camper are a pain to replace since most of them are inaccessible.
All in all, I think a left in place camper will be more of a pain than a pleasure and even if you tow it to and from the site, freeze protection will need to be done each trip. While this is a simple thing to do, it is a pain to fill then flush the antifreeze out each trip. Last year I just used a compressor to blow all the lines in my camper, it worked well so no flushing out the RV antifreeze was needed.
Either way you go (camper or small cabin) water and sewer is going to be a problem and likely be the most expensive thing you will need to do. I would suggest a small portable building (8x20) then outfitted with bunk beds, small Coleman stove for cooking, perhaps a propane heater for warmth. Put an outhouse in for your necessary things and forgo the showers while hunting OR put in a proper sewer system and water well if you must have water and sewer while on your trip. This could be preliminary for adding a house later if that is in your plans. If so, make sure to size the septic system accordingly.
   / Any Camper Advice? #7
We have an RV on our property we occasionally stay overnight in, mostly we use the bathroom when we are out working. As has been stated, left uncovered your roof will start leaking, ants and spiders will find there way in and tires will dry-rot. We have both electricity and water hook-ups so we can have AC and shower. As needed we pull it to a local RV park where we can empty the holding tanks and get a good system flush. A couple recommendations from our experience would be buy an RV with slide-outs, an 8-foot wide living area is cramped even for a one night stay. Buy/Build a cover for it, they are cheap compared to RV roof repair, provide shade and help maintain value. Leave it unlocked when you are not there, initially we locked ours up until some transient broke in and stole $20 worth of stuff but caused $900 damage to the door frame.
   / Any Camper Advice? #8
I知 thinking about buying a used camper (19, or 20 ft) to place on my farm/hunting property. I壇 like to spend an occasional night there in the fall and winter, but never when it痴 hot. Hopefully talk my wife into joining me. But there痴 no electricity, well, or septic system. It痴 about 20 miles from my home, not too far out of town. My buddy is interested in sharing 1/2 the cost, but he would use it occasionally for taking trips in the nearby mountains, but never too far, within a couple of hundred miles. I have no problem sharing ownership, as we jointly own many farm implements, as well as ownership of the farm.
Would solar help? How about dumping sewage and gray water? How often and where? It痴 a 300 acre rural property if that matters.
Thought about building a rustic cabin, but without electricity or water, just don稚 see that being wise, plus really don稚 want to have to go through the building permit process. I壇 like to keep it under 10 grand, but I see many fairly decent used ones in that range. Would this fly and if so, what should I look for?
Advice -
If there is a road or path where you plan on putting the "camp" first of all get a game cam or similar immediately and get it set out there before you do anything else so you can establish a baseline of what "traffic" is like. You'll probably see nothing.
Where do plan on parking it when it's not "hot"? Will you tow it back to the house? That would let you do maintenance over the summer near your tools.
Do you know what the permit regulations are? Places I own land don't require permits for under 200 sq ft. Which allows me to build a small "permanent" structure (next to which I can park a RV).
You write you have a cistern there but no well. Greenville, South Carolina gets 50 inches of rain, on average, per year. So figuring 4' cubic foot of ran per square foot of "roof" area that would be about 30 gallons you could catch per square foot. A small sturdy "outhouse" with a roof area of 5x5 would probably catch enough water (750 gallons) for your annual needs. And a properly designed and maintained "outhouse" can be moved easily, over another hole. Just get out there with your tractor and a PHD, dig a new hole, reposition the "outhouse".
Now the critical question - how are you going to access TBN?? Do you have a Mobley?
   / Any Camper Advice? #9
We have our camper at our ranch and use it while we (slowly) remodel the old farm house. I did run power to it to keep the ac working and the fridge off of propane. AC keeps it dry and not musty on the inside and I like to have cold water and beer at the ready for any emergency. Water/humidity are the enemies of campers so be cautious because they do rot. Tires on them are always bad (even if they look good they are bad) so replace the camper tires with 10ply industrial rated tires, just make sure to do it every five years or so. It is surprising how much work they take to keep up. Guess it is because they are really just small cheaply built mobile homes with moving parts (slide outs and the like) that get drug around on bad suspension.
   / Any Camper Advice? #10
For the price and square feet you are getting with the camper you could easily build a small cabin that would be better in every way.
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2006 INGERSOLL RAND AIR COMPRESSOR (A52472)
2006 INGERSOLL...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
