TMcD_in_MI
We had a heavy downpour on Friday, and another one on Saturday, and my JD 4310 hydrostatic was sitting out in both of them. Today I noticed the loader was raising in a jerky fashion and the power steering was acting the same way - it would move easily for a little portion of a turn, then lose power for about the same amount, then move easily, then lose power, and so on. The hydrostatic trans seemed to working fine. I checked the fluid level and found that it was higher than normal and milky.
It seems pretty clear to me that there must be water in the hydraulic fluid, and I plan to drain it, run it with some generic fluid plus Sea Foam Trans Tune for a while, change the filters, and then refill with JD fluid. It won't be cheap and I'd really like to not have to do it again, so I need to figure out where the water got in.
Before this happened, I had been seeing a little bit of hydraulic fluid leaking from the steering wheel area and oozing out onto the floor mat. Maybe a bad seal of some kind? I would suspect that that was the place where the rain came in, but I have a cab on the tractor, although the doors are off for the summer. I did check the hydraulic filler cap, but it was still nice and tight. I don't really have any other ideas.
So, tractor friends, do you think I have answered my own question, and enough rain could have sneaked in there to do what I described? Any other possibilities?
At least we got rain.
Tom
Tom
