jcwells
My wife and I bought 11 3/4 acres with a nice house and a 40' x 40' barn outside of Gunter, Texas in May. The house was built in 2004, but the barn was there long, long before that.
IMG_5187 by jcwellsq8, on Flickr
IMG_5231 by jcwellsq8, on Flickr
I'd like to get some input from all of you as to how best to rehabilitate this old barn, so that I can use it partly as equipment/hay storage, and partly as warm/dry/critter secure shop and storage.
IMG_5232 by jcwellsq8, on Flickr
The building is pole barn construction, and the "bones" of the building seem to be solid. The opening on the left is 8' wide, and extends the length of the building as shown.
IMG_5233 by jcwellsq8, on Flickr
There is a similar entry, 10' wide, from the back of the building, extending in about 30' that was once used for hay storage.
IMG_5253 by jcwellsq8, on Flickr
IMG_5252 by jcwellsq8, on Flickr
The rest of the building was set up as some kind of rough living quarters, likely for migrant workers. There is water and power to the building, but I have to figure out if there is a functioning septic system. It is a probably a +300' run to the aerobic septic system that handles the house.
IMG_5235 by jcwellsq8, on Flickr
IMG_5237 by jcwellsq8, on Flickr
IMG_5241 by jcwellsq8, on Flickr
IMG_5243 by jcwellsq8, on Flickr
IMG_5244 by jcwellsq8, on Flickr
The roof is mostly weather tight, other than a couple minor leaks. The floors are currently plywood that is pretty punky, laid across 2x6 floor "joists" that appear to be in contact with the ground. Whatever drywall was in place before has mostly been stripped out.
I'd like to go with a concrete floor in this part of the building, and stick with gravel pads in the equipment/hay storage areas.
I guess that I'm looking for advice on how to get this done, and on how to do the little things like fixing the outside skin to make it weather/critter tight. I've done a little bit of drywalling and 110V household electrical stuff, but really don't have any other useful construction skills.
Any ideas/suggestions/recommendations are fair game for this thread. You could probably say that I've got more money than brains, but I'm actually limited in both. A more-than-fulltime job means that I'm even more limited in time. I'd like to have most of the major stuff taken care of by next summer, but I can putter around on the finishings a lot longer than that.
Cheers...
John
Cheers...
John
